Old 09-30-2012, 10:21 AM   #1
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Hood Heat Shield
I'm in need of a new heat shield, was thinking of using Dyno Mat (Looking product at Home Depo) etc. I've seen the products on LMC but I'm not sure that I want to purchase there product! Any Ideas please address it! Thanks!!!
Smoke_Dog is offline   Reply With Quote
Old 10-01-2012, 09:01 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Hood Heat Shield
What do you mean by "hood heat shield"? Are you talking about insulation on the underside of the hood? What makes you think you need to replace it?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-07-2012, 03:01 PM   #3
Smoke_Dog
Smoke_Dog's Avatar
Falling apart!!! and getting sucked into the air cleaner!
K
Old 10-08-2012, 09:10 AM   #4
Keith Seymore
I'd throw it away and not replace it.
K
1979-1986
1986 - 2019
Old 10-01-2012, 09:08 AM   #5
Weasel Diesel
I got the LMC factory type insulator, and like it right much...
Weasel Diesel is offline   Reply With Quote
Old 10-01-2012, 12:44 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
I was wanting to replace mine but I wasnt sure if the LMC kit was a big enough single piece.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-01-2012, 04:26 PM   #7
Weasel Diesel
It is about the same size as OEM. Only thing about running a shield,... If you blow a hose or develop a heck of an oil leak the fan picks up, it destroys it.
Old 10-01-2012, 08:03 PM   #8
Keith Seymore
That's kind of where I was heading; my truck didn't come with the underhood insulation.
In fact, none of my vehicles have the underhood insulation.
Smoke Dog - I'd pull it off and not replace it if I were you.
K
1979-1986
1986 - 2019
Old 10-01-2012, 08:19 PM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
I removed mine and was gonna flat black underneath but undecided at this point
all of my vehicles have insulation....76 gmc, 2008 silverado and my new 2011 dodge ram hemi
1991 GMC Jimmy 4x4
Old 10-01-2012, 10:13 PM   #10
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
what is it supposed to do honestly? Just keep your hood cooler?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-02-2012, 06:51 AM   #11
Keith Seymore
Yah - and cut down on the noise in the interior some.
K
1979-1986
1986 - 2019
Old 10-02-2012, 08:53 AM   #12
legendman
legendman's Avatar
My 84 K20 with a diesel has it and I can see the need to cut down on the noise.
Also has extra insulation pieces on the firewall.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 10-02-2012, 09:46 AM   #13
Keith Seymore
Absolutely, additional pieces and of better material.
K
1979-1986
1986 - 2019
Old 10-02-2012, 10:45 AM   #14
tylervalo
Weren't they also supposed to supress any fires? I know C5's were designed to where if a fire occured the clips would melt and the insulator would fall down on the motor, hopefully supressing any fire.
tylervalo is offline   Reply With Quote
Old 10-02-2012, 10:54 AM   #15
Keith Seymore
I don't recall that being a design constraint - but - maybe I just learned something.
Although - keep in mind it was not released across the board; only for the "high end" models like Silverado, which leads me to believe it was not primarily a fire retarder. Maybe a secondary design consideration, but not primarily.
K
1979-1986
1986 - 2019
Old 10-02-2012, 11:00 AM   #16
tucsonjwt
I did not have the insulation shield in my 73 C20 or 76 Scottsdale and they were significantly nosier than my camper special 83 C20 Silverado with the insulation. For the low $$ involved I would have one. However, when the A/C compressor sprays oil it destroys a section of the shield.
tucsonjwt is offline   Reply With Quote
Old 10-07-2012, 03:18 PM   #17
88Jimmy4x4
88Jimmy4x4's Avatar
www.classicparts.com sells it and clips if needed
http://www.classicparts.com/1973-98-...ctinfo/38-375/
http://www.classicparts.com/1973-91-...ctinfo/38-386/
1991 GMC Jimmy 4x4
Old 10-08-2012, 01:02 PM   #18
Smoke_Dog
Smoke_Dog's Avatar
Thanks!!!
Old 11-18-2012, 09:25 AM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
did you ever order this and replace yours?
1991 GMC Jimmy 4x4
Old 11-23-2012, 03:34 PM   #20
88Jimmy4x4
88Jimmy4x4's Avatar
Last weekend I sanded my hood down and flat blacked it, looked okay but with the insualtion holes and a few dings it really wasnt all that appealing to the eye so I went ahead and ordered the insualtion and clips.
Insulation came in wednesday so I installed it today after cutting it to fit.
1991 GMC Jimmy 4x4
Old 11-23-2012, 06:05 PM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
that looks really good
i pulled it out, up here it holds salt and moisture,starts rust under it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-23-2012, 08:05 PM   #22
88Jimmy4x4
88Jimmy4x4's Avatar
I totally understand that, luckily here in Houston thats not a problem. Honestly If truck never came with it I wouldnt have installed a new one, in fact I had hoped the painting would have made it look good enough w/o one but I didnt like seeing the holes. My semi-restoration on this 1976 is almost finished so I wanted underside of hood to look as good as engine below it.
sneak peek
1991 GMC Jimmy 4x4
Old 11-23-2012, 04:11 PM   #23
GM-power
GM-power's Avatar
88jimmy, you get that insulation at classicparts?
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-23-2012, 04:29 PM   #24
legendman
legendman's Avatar
88Jiimy that came out nice.
Old 11-23-2012, 05:12 PM   #25
88Jimmy4x4
88Jimmy4x4's Avatar
Yes from classicparts, it has a thicker hard side that I put outward/clip side and its bigger than what you need. I just measured hood area, then cut legth/width. Then I used a coffee can as a guide to radius corners. The box said made in USA.....Arkansas I believe.
1991 GMC Jimmy 4x4
