Old 09-30-2012, 08:56 PM   #1
72 Super
72 Super's Avatar
WTB Flywheel cover 72 4X4 /w turbo 350
I am looking for a nice clean Flywheel cover for a 72 4x4 with a Turbo 350. Also need the correct mounting screws.
Thanks,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 10-01-2012, 07:29 PM   #2
72 Super
72 Super's Avatar
Re: WTB Flywheel cover 72 4X4 /w turbo 350
ttt
Old 10-13-2012, 06:56 PM   #3
72 Super
72 Super's Avatar
Old 10-13-2012, 08:38 PM   #4
Ironhorse
Ironhorse's Avatar
Went thru the same process, looking for the same. From what I have found out and been told by several board members the 350TH flywheel/dust cover is the same back then for 2wd or 4wd. I got one from a fellow board member and it fit fine to the transmission which is still hooked to the transfer case. Now have to look thru my many bolt cans to find the correct fastener. When I find the correct bolt I will post my findings.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-13-2012, 08:48 PM   #5
72 Super
72 Super's Avatar
Ironhorse, I also believe they are the same too. How is your changeover coming along??
Thanks,
Ray
Old 10-13-2012, 09:13 PM   #6
Ironhorse
Ironhorse's Avatar
The change over is doing pretty well but got a bit more involved than first planed. After removing the sm465/np205 combo decided to give the engine a "freshen" so to speak. Pulled it, put it on a stand and started the engine compartment degrease/clean up. Changing the oil pan gasket, rear main seal, timing chain and gear, water pump, power steering pump and hoses, changed the 2 bbl Rochester and intake to a Edelbrock Performer and a 600 Edelbrock carb, going to a Pertronix dist. conversion, installing a 4x4 dip stick, tall oil fill tube, stock '71-'72 style valve covers and a 4 core radiator.
Also giving the engine, accessories and brackets a new coat of paint. Chevrolet orange on the block and valve covers, water pump, timing chain and semi-gloss black on the brackets and such. Intake is powder coated silver/aluminum color. Installed new studs on the 4x4 straight down manifolds with POR15 cast iron Gray. Whew, this project got more involved than I first had in mind but then a LOT of my projects do that.
Wellington, Ks
Old 10-13-2012, 09:40 PM   #7
pickupman
pickupman's Avatar
Ray, did you find you a 4wd? I will check tomorrow I may have a cover.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 10-13-2012, 10:36 PM   #8
72 Super
72 Super's Avatar
Hi Bill,
Yes I did, I bought a 72 LWB 4X4.
Thanks,
Ray
Old 10-14-2012, 08:39 PM   #9
72 Super
72 Super's Avatar
Originally Posted by 72 Super View Post
Hi Bill,
Thanks,
Ray
Bill any luck?
thank you,
Ray
Old 10-13-2012, 09:50 PM   #10
cwilkie
Chance
cwilkie's Avatar
I have a newer plastic universal cover I bought from summit that I did not use. $20 shipped. It will work with a th350 or th400.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 10-13-2012, 10:37 PM   #11
72 Super
72 Super's Avatar
Thanks, but I would like to find a factory original 350 cover. I know a turbo 400 cover will work too, but the starter cut out is wider.
Thanks,
Ray
Old 10-14-2012, 07:16 AM   #12
hilljob26
hilljob26's Avatar
i have one off of my 70 jimmy,,would that work for ya,,it has a th350,,,i will need to look at it again to make sure its not broke anywhere
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 10-14-2012, 10:20 AM   #13
4oldcars
4oldcars's Avatar
I think I have one somewhere in the garage and I'm close enough you can pick it up. I'll check today. If I have one, it's yours.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 10-14-2012, 12:33 PM   #14
4oldcars
4oldcars's Avatar
I found a lot of things, but no dust cover.
4oldcars
Driving:
The ones I let go:
Old 10-14-2012, 12:39 PM   #15
tll74
"Junkyard Dog"
tll74's Avatar
I can do a nice original metal one for 30.00 shipped, Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 10-14-2012, 08:41 PM   #16
72 Super
72 Super's Avatar
Tom, I will wait to hear from Bill. If he doesn't have one, I am interested in yours. Is it an original turbo 350 cover? any pictures?
thank you,
Ray
Old 01-16-2013, 01:38 PM   #17
tdkosta
tdkosta's Avatar
Is your dust cover still for sale?
tdkosta is offline   Reply With Quote
Old 10-14-2012, 08:40 PM   #18
72 Super
72 Super's Avatar
thanks for looking. I know how that can be, can find everything untill you need it
thanks,
Ray
Old 10-14-2012, 08:50 PM   #19
pickupman
pickupman's Avatar
Ray, sorry I did not make it down to the garage today. I will tomorrow eve. I know I did have some NOS ones at one time if I didn't get rid of them all. will let you know as soon as I can. You will have to shoot me some pic of what you found
Old 10-15-2012, 01:36 AM   #20
tll74
"Junkyard Dog"
tll74's Avatar
Ray, yes I have one off a TH350. Just let me know if it gets to me and I'll post a pic. Thanks, Tom
Old 10-15-2012, 05:29 PM   #21
pickupman
pickupman's Avatar
Ray, here is a picture of the one I have. let me know if interested. you can email me if you like about it. It does have a few wrinkles in it from tooling
Old 10-15-2012, 06:42 PM   #22
72 Super
72 Super's Avatar
Bill, If that is an turbo 350 cover and NOT a turbo 400 cover, I am interested. Pm coming your way.
thank you,
Ray
Old 10-17-2012, 07:18 PM   #23
Ironhorse
Ironhorse's Avatar
Ray, I found out today that the 350TH mated to my np205 actually uses the same bolts or fasteners as is used with the oil pan and timing chain cover. I think they are 1/4 - 20 thread. I have several of them spare if you are in need. May not work on your transmission but threaded in very nicely on mine. If you do not have any PM me your address and I will mail some to you in a bubble pack mailer, no charge, FREEBIE. Just paying it forward for some things I have received FREEBIE style from fellow board members.
Wellington, Ks
