Old 10-01-2012, 12:17 PM   #1
mongoose
mongoose's Avatar
4x4 noob needs help!!!
Well, some off road help...
I'm looking at buikding a new truck, prerunner/FDR special and have a couple questions.. Now I have a bunch of old blazer crap that I was going to use, and was wondering what the difference bewteen dana 44 and the stock 10 hubs/spindles are? Should a really try and seek out a 44 set up or can I use the 10 bolt stuff? I'm hoping to be 3000lb running(v8 s10), so it's not a pig by any means.. Also, since I'm not using the spindles are designed can I hack off the outside bit as I don't need the locking part of the hubs? That doesn't support the sindle in anyway right? So just make a new cover for it to keep everything clean..
Anyone?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-01-2012, 03:08 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 4x4 noob needs help!!!
Some say the 44 and the 10 bolt are the same strength, some say they arnt. I am in the "they are the same" crowd.
You cant "hack" the hub off, If that's what your talking about. You can leave the lock out off and put a full time cap over the hub.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-01-2012, 03:54 PM   #3
obijuan
6 lug Dana 44 and GM 10 bolt front axles are dimensionally identical from the knuckles out.
Also why even run axle shafts? Then for that matter why a solid axle in a prerunner?
obijuan is offline   Reply With Quote
Old 10-01-2012, 07:45 PM   #4
mongoose
mongoose's Avatar
im not running any front axles... I'm wanting to run the spindle part only on my own fabbed up spindle instead of running a cast 2wd piece.. see pic... That's also why I was asking if I could chop off the rest of the hub.. as the bearing that hold it on are way in there.. I'm just afraid of the nut working loose and the bearing coming apart/falling out on me.
the one I'm doing would be the one on the right...
Old 10-01-2012, 09:14 PM   #5
obijuan
There's not much spindle showing after both nuts and lock washer are on there. But I like the replaceable common part idea.
