Any interest in a 2wd to 4wd conversion kit?
I'm looking for some input here. Does anyone see any interest in an inexpensive bracket kit to convert 48-54, 55-59, or 60-66 2wd trucks to 4wd using 73-87 lift springs?
I see a lot of people try to mount the old body on a newer frame, and it just never turns out right without a lot of work, shortening the donor frame, or a huge body lift. I've been looking to convert a 60-66 truck as a project for myself. I've got axles, drive shafts, and a t-case begging to get put under a truck. I can easily design the brackets in CAD, and have them laser cut and formed for a reasonable price. Do you guys think there would be a market for a kit? I could also do a kit to mount '88 and up 63" rear springs on the back. I'm not looking to make much money here, I just figured if I took the time to make good brackets, maybe other people would be interested in them. What year would bring the most interest? I figured I would start with the 60-66 since that's what I want, but I can get a free 55-59 frame that I could mock up brackets on too, if there's a demand for it. Target buyer would be someone who wants to use the truck more than you would an original (rare) Napco conversion truck. One thought I had is that, ideally, on the 48-59 stuff, I would make it bolt on. That way no permanent changes are made to the frame. But I'm not sure if that would even be important to most people doing the conversion. Any input? Thanks! |
Re: Any interest in a 2wd to 4wd conversion kit?
I think you have a good plan. I have a 62 shortbed 4x4 chev that need a new suspension. I also think a 67-72 kit would be in demand. I can find worn out 4x4's for about 1500, so that would give you a good price point to start from. Also, you need to have an option for trans/transfer case mounts.
You should have some more input from other experienced users soon!
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
If you could do it cheap enough and bolt in it probably would sell i think.
Thanks for the responses guys
1939 Chevy 1/2 Ton (30 year long father/son project) 1997 Jeep TJ on 1 tons 2011 Cummins 1972 GMC Jimmy |
![]() Join Date: Apr 2009
Ive been kicking around converting my 59 to 4wd. The springs don't seem too involved. Its the steering that seems complicated. Most guys seem to use a 73+ 2wd box and convert to crossover steering. If you come with an Idea for for a 55-59 set up LMK.
Posted via Mobile Device |
I am about half way through my 1959 2wd to 4x4 swap. I wish I had parts to bolt on, would have saved so much time. Go for it in making the parts. Nobody else has them.
Interesting you would post this. Today I was going to purchase a kit from Sky Manufacturing (their S10 SAS kit) to do just what you describe. This will be the second 55-59 I've made 4x4. The first was my dads 56 using stock rearched springs bolted to a 72 Blazer axle. Stock steering box/pitman used. I have to say, that thing rode like a tractor. I was told by several suspension experts that a shackle reversal would make it ride nicer. I drove that beast clear through college like that and I loved it.
So, I made all my mistakes on that truck. Plans for this second 56 will include the shackle reversal using something like the above mentioned kit and using either 1967-72 2.5 in. wide Chevy springs or Wagoneer springs. It will have crossover steering using a 78 IH Scout p.s. box and a kit from ORU, DIY, or Sky mfg. Some people cringe when I mention the Scout steering gear, but it is a Saginaw gear just like GM uses and I'm told my p.s. pump hoses will screw right to it without modification. Why not just use a GM box you ask. In the past 25 years I've seen dozens of people do just that on 55-59 conversions (steering box on outside of frame rail) and all of them that use tires larger than 33 in. complain about the tire hitting the steering box and limiting right turn radias. The Scout box doesn't interfere because it mostly sits on top of the frame rail. So, back to the topic. If you are thinking of building a front spring hanger kit for 55-59 Chevy 4x4 trucks that is strong and inexpensive count me in. I suggest you look at the Sky Mfg website at the S10 SAS kit to get an idea of what I am looking for in a kit. I'll be standing by. ![]() ![]() ![]() ![]() ![]() ![]() Posted via Mobile Device |
I would be interested, in the process of looking for a 4x4 donor truck to swap a 66 suburban. Let me know what you decide to do?
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
Thanks for the responses guys. I'm in the process of trying to find a decent truck to start with. I'd rather focus more on the drive train than the body work....
I'm familiar with the Sky Manufacturing parts. They have some good stuff. I like the Scout steering box idea and how it would keep the box up on top of the frame. The only down side is the long sector shaft length, which can be a weak point. But that's only with hard wheeling and big tires. Keep the ideas and comments coming guys! I'm liking this more and more ![]()
#10 | |
I mounted a 74 box on the outside like you said and will just deal with the turning radius, if its a PITA than will probably convert to something like this.
I haven't forgotten about this thread. I've done a lot of research on this and here's where I'm at.
1955-59 As OrrieG said, it's a straight swap to put a front axle with a 32" spring pad witdth into these trucks. He's got a good write up on it. My thought was that some people would want to be able to run '73-87 front springs with poly bushings, so it could actually do some mild wheeling. I bought a rough '56 short box frame stripped it down, and started to do some mock up on it. Basically, once the frame is stripped (all the rivets for the factory stuff removed), it's just a thin walled weak frame with a lot of holes in it. It would take a lot of work to make it strong enough for mild wheeling. I did go ahead and design brackets though. But since the frame width is perfect for mounting springs under the frame, someone could easily order generic leaf spring mounts and, with some work and forethought, hang any leaf spring they want under the front. So I sold the frame and moved on. 1960-62? I believe these 1/2 ton trucks have an X Frame with torsion bars, making it pretty much impossible to convert those year trucks to 4wd. 1963-1972 Despite the body style change, these truck have pretty much the same frame rails. The differences are the front frame horns and the body mounts. So I've been trying to find a truck, but my budget is low and my expectations are high. I'm in no rush so I'd rather wait for a good truck to start with. I'd still like to make some simple brackets to swap leafs into these years of trucks, but don't hold your breate. For those who are wanting something soon, check out these companies websites. They all offer a lot of options for mounting brackets and tabs. Barnes4x4 Ballisticfabrication Polyperformance Bluetorchfab Artecindustries Ruffstuffspecialties Copperheadfab And DIY4x Diy4x has a spring hanger kit listed for '69-72 4x4s. I think it could be easily modified for the 2x's. It's pricey, but it's a nice product. ![]()
Don't all the pre 1960 trucks have leaf springs under the front?
Yeah, but if you wanted to use the truck for any type of offroading, you wouldn't want to do it on stock, 50-60 year old springs. Plus if you could mount 73-87 truck springs under it, you could lift it as much as you want with off the shelf springs
![]() Join Date: Oct 2012
Interested also. Don't like the body swap idea either.
#15 | |
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
#16 |
Zero Albedo
I'd be interested in a 64-66 1 ton kit that would eliminate some of the guesswork.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
#17 |
![]() Join Date: Mar 2011
Seems like you have alot of interest, Just make sure you do the research and make it a kit that is pretty easy. Most people doing conversions have the skills to do it, BUT there are some out there with limited experience and skills. Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
#18 |
55-59 TF 4WD is a bolt on conversion as far as the axles are concerned. Steering can be accomplished different ways. 4" lift blocks in the back are needed to level it out. If you want a different spring length cut the rivets and move the shackles. 55-59 frames are consistant width (34") full length, only vertical offset is above the rear axle.
#19 |
About 7 or 8 years ago one of the Peterson's mag's (pretty sure it was 4wheel & off road) converted a 4-5-6 truck to 4WD. I'm a chronic hoarder, especially when it comes to car magazines, but for the life of me can't find that issue. If anyone else is a regular reader, I'm pretty sure it was when Frieburger (sp) was at the helm, gonna say around 2002-2003 time frame. I've searched their archives with no success but continue to look. I don't remember how they did it, but I do remember they put leafs and a solid front axle under a 2wd frame.
#20 |
I was wondering if you had a chance to make this kit. I want to turn my 64 2x4 1 ton dually in to a 4x4.
#21 | |
I remember the build, they left the trailing arm rear suspension and added hangers to the front. I wish they would have shown that thing wheeling, I was interested to see how the rear would flex with the stock stuff. |
#22 |
That is essentially a 3 link isn't it? I'd still like to find that article. I guess now that Frieburger is on facebook I could ask him. It also seems like it was when the tech articles were still in black and white.
#23 |
![]() Join Date: Oct 2006
The thing about using the FSJ wagoneer,cherokee,J-truck axles is that the front axle is spring under.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#24 |
Ive bought several items from Kert at DIY4X and all have been great. ORD sells some good stuff too but more money and I like the look of the DIY4X items that Ive bought. Just my 2 cents.
I considering a 67 2wd to 4wd conversion and not sure if I want to use the stock hangers or all the stuff I bought from Kert. Only down fall is that I have 56inch front and rear springs which gave my burb about 7 1/2 inches of lift. Not sure I want the 67 that high.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#25 |
how much different are the 4x4 frames from 73-87 to 67-72? width, contour etc . thinking of using 73 or newer frame and running gear under my 67 2wd thanks
