Old 10-02-2012, 06:06 PM   #1
chill68
chill68's Avatar
68 Bed Restoration
Right now I'm driving my '68 GMC without a bed. The bed is sitting in my backyard right now. I want to get it cleaned up and looking nice before I put it back on. Plus winter is coming up and without any weight on my rear end, I'll be slippin' and slidin' all over the place. I need to replace some of the supports, patch some holes, and repaint the whole thing. Any comments or suggestions?
1968 GMC 1500 Long Fleetside 327 "The Chillest!"
1971 Chevy C/20 Long Fleetside 350
chill68 is offline   Reply With Quote
Old 10-02-2012, 06:11 PM   #2
chill68
chill68's Avatar
Re: 68 Bed Restoration
Here is the bed flipped over. You can really see the extent of the damage to the supports. Has anybody ever replaced these? I'm planning on just cutting out the spot welds, taking them off, and putting in new ones.
Old 10-02-2012, 06:20 PM   #3
NoNeck
NoNeck's Avatar
I would start by media blasting the entire bed. This would give you a better indication of exactly what you have and how extensive the rust has become. My son (CC69Rat) and I just completely disassembled a short fleet bed, and I can tell you that was a pain.
I would patch the floor as best you can and get it as straight as you can. While you could replace the floor with a repo, that would cost you about $1000, plus shipping. Not cheap.
You didn't say if it was to be a daily driver or not, but if so I would eliminate all the rust first. Then paint the bed inside and out with a quality Epoxy primer. If you have to wait to have it painted, this will at least help keep it sealed over the winter.
If it's a daily driver, then I would just have a bed liner sprayed (or brushed in). Not knowing your budget/expertise that's about all I can suggest. I'm sure there will be others to offer their advice to you.
Oh, and WELCOME TO THE FORUMS!
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 10-02-2012, 06:22 PM   #4
NoNeck
NoNeck's Avatar
Oops... I didn't see your second post until I had hit the "Reply" button. You might be better off just finding a better bed. I didn't see the bottom supports.
POP
Old 10-02-2012, 07:03 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I'd look for a replacement as Noneck mentioned. At least one with a better floor. The sides and wheelwells seem to be okay and if the front is not rusted out, you should keep it also. It's easy to dismantle after you grind the welds in the back of the bed that attach the sides to it. I've had mine completely disassembled and left just the bed bottom on the truck.
In you case it's probably not worth the time and effort to fix it with the floor as rusted as it is.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-02-2012, 08:45 PM   #6
midniteblues
midniteblues's Avatar
replace the cross sills,clean up the rust,coat the bottom with your fav sealer, patch holes in the floor maybe some bedliner (perhaps only on the floor) then throw one of them wood kits over it.
it really isnt that hard to make the wood on your own if you have the basic tools sure beats the snot outa a 1g bed floor. if you dont want wood just patch it up and get a good rubber mat to cover it
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 10-02-2012, 09:01 PM   #7
GMCJOE
GMCJOE's Avatar
If my bed was in that condition, I would cut the floor out. Media blast the rest, and repair what needed to be. Paint it. Then put a sweet wood floor in.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-02-2012, 09:25 PM   #8
med.bronze
med.bronze's Avatar
x2
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
