Old 10-02-2012, 07:41 PM   #1
Tx79chevy
Tx79chevy's Avatar
Door won't open
Went to get in my truck about an hour ago and now the door won't unlock from either the inside or the out. I had to climb through the passenger side to get in and out. I haven't had a chance to take the door panel off to look at it yet. Any ideas of what might have happened? Not that it matters but its an 87 silverado.
Tx79chevy is offline   Reply With Quote
Old 10-02-2012, 08:12 PM   #2
Squareforceone
Squareforceone's Avatar
Re: Door won't open
my truck use to do that lubed them up really good and havent had an issue since
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 10-02-2012, 08:35 PM   #3
tucsonjwt
Re: Door won't open
If power door locks, think inoperative power door lock switch or actuator. I also had a corroded lock rod which was sticking. You might have to try a "slim jim" to open the door, then take off the door panel and investigate. I am assuming that the door lock rod (door lock button) is not moving. I suppose the latch could be defective, but I have never had that problem.
tucsonjwt is offline   Reply With Quote
Old 10-03-2012, 12:43 AM   #4
76Charlie
76Charlie's Avatar
Re: Door won't open
My truck (manual lock) does this ALL the time. I would lock the door, try to get out, then realize it was locked and try to unlock it and it won't go, you have to push the outside handle like you are opening the door and it will un-jam your lock mechanism and you should be able to unlock it.
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY!
76Charlie is offline   Reply With Quote
Old 10-02-2012, 08:33 PM   #5
Car'n'Guitars
Car'n'Guitars's Avatar
Re: Door won't open
My truck did this and I had to get in the door and physically unlock the door the mechanism. I think that some of the rods that worked the mechanism were bent but I didn't really look into it, but that's what it felt like.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 10-03-2012, 02:50 AM   #6
1981Stepside
1981Stepside's Avatar
Re: Door won't open
same thing happened to me too - mine turned out to be the push button knob too - sprayed penetrating oil on the spring inside the door and on the sides of the knob itself - fixed it right up
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 10-03-2012, 11:02 PM   #7
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Door won't open
Try pulling the inside handle all the way to the stop, then let it go so it slams back to its original position; now try pulling up the door lock.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-03-2012, 11:29 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Door won't open
My door locks did this once when it sat for winter last year. I just got a tarp layed it in the ground and hit the window with a hammer. Lol 20 dollars and some lube later I had a new window and nice smooth door locks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-04-2012, 06:06 PM   #9
TDS-MN
Re: Door won't open
I'll concur, that a fresh application of lube should solve this issue for you. However, when I was stuck with this problem, I really had a difficult time getting the door panel off, with the door closed. Finally did, but was not fun at all.
Once you get access to the door insides, there is a bracket on the rear edge of the door where the strike is, that 'rocks' up and down, with the manual lock that comes out the top of the door. Once you can get to that, you may be able to pop it to it's other position, to unlock the mechanism. I had no luck using a 'slim-jim' to try and unlock mine. This is probably where the lubrication will make the most difference, solved mine.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 10-10-2012, 07:44 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Door won't open
try the handles,need some lube....my 88 had one door button stuck half in
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
