Old 10-02-2012, 11:48 PM   #1
Hunty the Toad
Front suspension swap
I'm new to the forums, and my truck is a 1969 gmc custom 2wd, with a 350 v8.
I'm wondering about swapping out the front suspension with that of a more modern car, is there anything that's "easy" or popular with these trucks, sort of like the crown vic swaps in late sixties ford pickups.
Thanks, Hunty
Hunty the Toad is offline   Reply With Quote
Old 10-03-2012, 09:07 AM   #2
yuccales
yuccales's Avatar
Re: Front suspension swap
Welcome from Northern California. As for your question, I can't help you out because I'm one of those old timers that like my drum brake, no sway bar equipped trucks! I know others will chime in soon to help you out.
PS, we need pics!
yuccales is offline   Reply With Quote
Old 10-03-2012, 09:20 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Welcome!! Try any GM truck from 1973 up to about 1986.The entire front crossmember will bolt up with one hole on each side to modify.Or you can mix and match parts to change it over.A search will net you more info than you can read.Get the PS and PB while you're there.You even have the option of staying 6 lug or going to the 5 lug pattern.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-03-2012, 10:14 AM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
I'll be installing one of these on my truck next week.
http://www.nolimitparts.com/prodinfo...umber=WRIFS3-C
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-03-2012, 11:02 PM   #5
71tahoe
71tahoe's Avatar
Take a look at porterbuilt. Corvette dropmember and it's bolt in.
71tahoe is offline   Reply With Quote
Old 10-08-2012, 09:53 PM   #6
fatgump
fatgump's Avatar
Low68 and I installed one of those.
fatgump is offline   Reply With Quote
Old 10-03-2012, 11:04 PM   #7
Hunty the Toad
Cool, thanks for the replies, ill get some pictures on
Old 06-01-2013, 07:05 AM   #8
elf w/capital T
Not sure if you found a swap but i have been researching myself, seems like the 73-87 crossmember with 5bolt disk brakes is what ill be doing, bigger components, stronger and then ill know for sure what MOOG parts to get later down the road, ball joints, pads, tie rods, pitman, idler arms and bushings, its an easy swap just two maybe three holes need to be drilled.
elf w/capital T is offline   Reply With Quote
Old 07-03-2013, 01:30 AM   #9
Rusty69
Is there a thread on here showing the swap being done? I can get the stuff from the local pull-a-part, just don't know what to get. I want to use the 73-87 stuff because I don't have a few thousand to drop on the aftermarket stuff. I would have to live in the truck because my wife would kill me when I got home. Haha
Rusty69 is offline   Reply With Quote
Old 07-03-2013, 02:02 AM   #10
andrewmp6
Rusty basicly you take the front crossmember and whole front suspension.But before you use it i would rebuild the brakes and a arms so you have it all new and ready to be used.
1969, front, gmc, suspension, swap
