Old 10-03-2012, 02:59 PM   #1
kissingbug1978
Seeking Wisdom
Ok. Starting rebuilding my 350 and after tearing the engine down found out that I was going to a 5 week school and shortly after returning I will be moving to Fort Polk, LA. So, I replaced rings, bearings, timing set, and the oil pump, put all back together and put it in the truck. After a rookie mistakes I got her fired up and it sounds amazing. BUT... during my rush to get things put back together before going to school, I didn't do any work to the heads and now after it runs for a little while it begins to smoke on the drivers side only. Which is why I started the rebuild in the first place. Engine was clean inside. No scaring in the cyclinder walls. Bearings were a little wore and the oil pump was weak. But nothing that should make it smoke.
I'm thinking(hoping) that I've got a head problem and hopfully its just a valve seal. I'd be interested in hearing ideas from some of you that have more experience.
kissingbug1978 is offline   Reply With Quote
Old 10-03-2012, 03:52 PM   #2
1963c-10
1963c-10's Avatar
Re: Seeking Wisdom
Being that you just rebuilt the engine...Id say valve stem seals. How much run time on the engine since the rebuild?
1964 Short bed trailer
Old 10-03-2012, 04:14 PM   #3
jonfletch01
Re: Seeking Wisdom
It does sound like valve seals... you could try a heavier weight oil.. Might help... Probably won't solve the problem...
jonfletch01 is offline   Reply With Quote
Old 10-03-2012, 05:07 PM   #4
contagious102
contagious102's Avatar
Re: Seeking Wisdom
It's more likley worn valve guides and seals.Need to pull the head and have the head reworked when you have time.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 10-04-2012, 12:45 AM   #5
Captainfab
60-66 Nut
Re: Seeking Wisdom
You say you just replaced the rings. Are you sure the block didn't need to be bored?
Old 10-04-2012, 12:15 PM   #6
TopFuel1966
TopFuel1966's Avatar
Re: Seeking Wisdom
..........or at least break the glaze on the cylinder walls with a hone. If you didn't the chances of the rings properly seating are slim to none.
TopFuel1966 is offline   Reply With Quote
