Old 10-03-2012, 07:45 PM   #1
Caddieup
Caddieup's Avatar
Will a 1954 cab/bed fit a 1950 frame??
Will a 1954 cab/bed fit a 1950 frame? The frame on my 54 is in fairly bad shape.
I just found a 1950 frame for sale and I'm not sure if it'll work or not.
Here's a cpl pics of the frame for sale.
Caddieup
Caddieup is offline   Reply With Quote
Old 10-03-2012, 11:16 PM   #2
chev3600
chev3600's Avatar
Re: Will a 1954 cab/bed fit a 1950 frame??
It's not a straight swap but close. The rear of the early frame has a taller kickup over the axle requiring you to raise the bed floor or modify the frame. Seems like I had to slot some of the bed cross sill mounting holes too.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-03-2012, 11:23 PM   #3
mr48chev
mr48chev's Avatar
Yes, my 48 is actually on a 54 Frame.
As Chev 3600 said there are some differences that you will run into. The best thing is to set the rolling chassis side by side and make notes on the differences that might be an issue. A good frame and a bit of work trumps a bad frame any day though.
There are some differences the biggest being the brakes. The 54 uses Bendix design brakes while the 50 uses Huck design and the Bendix are self energizing while the Huck aren't.
Old 10-03-2012, 11:50 PM   #4
Caddieup
Caddieup's Avatar
Thanks for the help!!!
The current frame has been modified for the bed to sit flat.
After looking at different photos, reading specs on both, and just the overall shape the current frame is in, I don't think the current frame on the 54
is worth keeping.
Specs I found: http://chevy.oldcarmanualproject.com...esto/54129.htm
http://chevy.oldcarmanualproject.com...resto/5070.htm
It's been cut,
welded,
angle ironed to death,
just think I may be better off scrapping it.
Caddieup
Old 10-04-2012, 10:47 AM   #5
mknittle
mknittle's Avatar
Yeap! I've been framed
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-04-2012, 11:03 AM   #6
Caddieup
Caddieup's Avatar
that's what I was afraid of!!!!
Caddieup
Old 10-08-2012, 12:51 AM   #7
55dude
55dude's Avatar
WOW! Good thing you found a replacement frame.
55dude is offline   Reply With Quote
Old 10-08-2012, 12:01 PM   #8
Caddieup
Caddieup's Avatar
The frame has been purchased, truck on the way!!!!
Caddieup
