Old 10-03-2012, 11:15 PM   #1
72GMCDD
Spring shackles
Ok guys i need some help. I have a 1972 GMC 1/2 ton 2wd and it has rear leaf spring suspension. Does anyone know where I can get some new spring shackles? I've tried LMC and Brothers they don't carry them. Thank y'all for the help.
1972 gmc 1/2 ton long bed converting to short bed
72GMCDD is offline   Reply With Quote
Old 10-03-2012, 11:26 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Spring shackles
I might have the stock shackles I took off of my 1972 GMC 1500 Super Custom. I installed a set of 2" drop shackles from CPP in there instead. I just recently moved so I have everything in my shop either still in boxes or in an exploded mess in the corner. There is a chance that they got pitched...
I'll dig for 'em. If I find 'em... they're yours for the cost of shipping.
They'll need new bushings. As these were pretty worn out.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-03-2012, 11:28 PM   #3
Re: Spring shackles
GM just recently depleted these from stock. I know some aftermarket companies make them,just don't know who to tell you.
Old 10-03-2012, 11:30 PM   #4
GASoline71
GASoline71's Avatar
Re: Spring shackles
These are what's under my truck now.
http://www.classicperform.com/Store/...k/6372SHKR.htm
Gary
Old 10-03-2012, 11:47 PM   #5
72GMCDD
Re: Spring shackles
I saw those but I bought 3 inch drop leaf springs and saw the shackles were 1 to 2 in drop. If I did those would I have c notch the frame since it will make it a 4 inch drop in the rear?
Old 10-03-2012, 11:52 PM   #6
GASoline71
GASoline71's Avatar
Re: Spring shackles
Okey doke... anyways... my offer still stands. If I find the stockers off of my '72... you can have them.
Check my reply in post #2.
Gary
Old 10-04-2012, 12:06 AM   #7
72GMCDD
Re: Spring shackles
Ok if I can't find any I will let you know. Thank you for the help
Old 10-04-2012, 08:15 AM   #8
volksworld
Re: Spring shackles
i used 73 and up stock shackles.the later springs are 1/4 inch wider so i tack welded two 1/8 inch flat washers to the inside ...the bushing on the frame bracket is the right size .don't remember where i got them but it was brothers or year one i think...wondered why the drop shackles fit early and late but stock didn't....guess the're flimsy enough to tighten that extra 1/4
volksworld is offline   Reply With Quote
Old 10-04-2012, 08:59 AM   #9
bigpaul
bigpaul's Avatar
Re: Spring shackles
I bought new ones from napa for my 71 leaf spring.
bigpaul is offline   Reply With Quote
Old 10-04-2012, 03:02 PM   #10
72GMCDD
Re: Spring shackles
@volksworld I just got some for a 73 was yours about a 1/2 an inch shorter? @bigpaul
i'll check them out thanks.
Old 10-06-2012, 06:05 AM   #11
volksworld
Re: Spring shackles
dont think so but truck and leftover parts are in new york and i'm currently in north carolina so i can't check
