10-04-2012, 10:34 AM | #1 |
how quiet is your truck inside?
I was wondering how quiet can you get these trucks at hiway speed,I do one thing to fix air noise and create a new one.
10-04-2012, 10:55 AM | #2 |
Re: how quiet is your truck inside?
Mine has no rattles or squeeks, only exhaust noise. I used foam on the back of a lot of trim to keep it from rattling and I removed the belts, the rollups on those always rattled on mine. Apart from that I do have wind noise from the vent windows.
10-04-2012, 11:20 AM | #3 |
My truck is about as quiet as a group of skeletons playing rugby on a tin roof...
That said its an older model and I have absolutely no sound proofing at all. Dynamat or fat mat is great to bring down the rattles as does tightening down trim and liberally applying grease to suspension Posted via Mobile Device
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna Last edited by Billett; 10-04-2012 at 11:37 AM. |
10-04-2012, 11:25 AM | #4 |
Not too many rattles at high way speed. Just wind noise from the door and vent seals. I need to replace them but....
I've seen some stuff that you can put under the floor carpet to help quiet things down.
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
10-04-2012, 03:11 PM | #5 | ||
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-04-2012, 04:42 PM | #6 |
You can use the vent windows out of the 88-91 suburban to quiten down the leaks there, there are quite exspensive now though.
I used some cheap role roofing from homedepot in my crew. I used it on the doors, floor, roof and rear cab panel and my truck is very quite.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
10-04-2012, 05:51 PM | #7 |
Very quiet in town - all stock 83 C20. On the the highway, wind noise around the roll up window, even though I replaced all window run channels and felts and door seals. I suspect aftermarket parts are the culprit.
10-05-2012, 02:06 PM | #8 |
10-06-2012, 09:52 PM | #9 | |
My lifted K20 Burb really doesn't have wind noise, but does have a lot of tire noise. My lifted K30 is really pretty quiet, just some tire noise and some rattles normal for a truck pushing 35 years old. My little '84 C10 is one noisy SOB. The left vent window has been really noisy for years, just the other day I crammed some sticky-back weatherstripping into it and it made a big difference. But I still hear the exhaust and a ton of road noise. I haven't driven my K5 in so long that I don't remember how noisy it might be.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
10-04-2012, 11:31 AM | #10 |
Big Gulps Huh? Whelp...
Mine is solid...quiet, no rattles, and the stereo sounds great! lots of bass at really high volume and no rattles inside!
Stripped and cleaned Floor Roof New carpet with Foil Backed EVA Insulation Behind all door panels Done... 13.5" JL Audio TW5 with Polk MM components up front and Polk MM coaxials in back on a JL HD900/5 amp
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
10-04-2012, 12:41 PM | #11 |
Insanely loud. No sound proofing, no window weather stripping and a Flowmaster that exits about a foot behind the cab under the bed. But it's fun to drive and the stereo is crappy anyhow.
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
10-04-2012, 12:43 PM | #12 |
dang thats a great interior setup...nice work/design
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-04-2012, 01:36 PM | #13 |
Imagine a drum...that is your can and everything is pounding on it and making noise. That's how our trucks are
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-04-2012, 02:18 PM | #14 |
Not very quiet at all, but I prefer it that way!
10-04-2012, 02:24 PM | #15 |
With underlayment and 1/4" insulation below the rubber matting, FRANKENTRUCK stays pretty quiet, unless I've got the Kenwood powered!
Duals straight out the back helps reduce exhaust noise, too. Good luck, Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
10-05-2012, 01:32 AM | #16 |
78 Big10 454
Other than dual glasspacks, my stock truck is whisper quiet. I had an irritating whine for awhile. Once I installed a new fan clutch and kicked my old lady to the curb, the truck got quiet - REAL quiet.
1978 Chevy SWB C-10 2WD 454/400 |
10-05-2012, 02:06 AM | #17 |
My 1991 V3500 crew cab dually is super quiet. Even at 70 mph with a th400 and 4.10 gears. I can have a regular conversation with someone sitting on the other side of the cab with the radio on.
10-05-2012, 09:03 AM | #18 |
Lotīs of wind noise from the vent windows at highway speed, other than that not so bad.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
10-05-2012, 01:32 PM | #19 |
its all wind noise for me. windows, vent windows and the top of the door because of the worn hinge pins.
oh yea, the transmission. sm465s make a bit of noise too
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
10-05-2012, 02:34 PM | #20 |
No No
my 76 is missing felt around the windows and the door rubber isn't great either but nothing more then alot of wind noise and I do have a full padded interior. on my old 86 Gmc it had just factory carpet the no headliner option. before the exhaust was done you could hear a mouse fart doing 80
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
10-05-2012, 03:12 PM | #21 |
last week i has 3 dirtbike in my truck and hit a speedbump. my drivers side header hit hard enough to cause a leak at the head. its really annoying
10-05-2012, 03:38 PM | #22 |
Not bad after sealing the vent windows, Even though you still have to pull over to call someone. A good sound system helps a lot to mask the noise. If it were to have all the padding weather stripping and padded headliner it would be rather quiet.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
10-05-2012, 05:11 PM | #23 | |
Posted via Mobile Device |
10-05-2012, 04:10 PM | #24 |
Moderator
My stock '87 swb was acceptable. My '71 is like a torture chamber though.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
10-05-2012, 08:29 PM | #25 | |
No No
