10-04-2012, 02:56 PM | #1 |
Manual choke to Electric choke
Hey everybody,
I was wondering how hard it would be to go from a manual choke to an electric choke. I'm looking at switching to a smaller carb as I have a edelbrock 750 which is just to much for my engine currently. Some of the edlebrock 600's i've been looking at have electric chokes.
1970 Chevy C20 |
10-04-2012, 03:13 PM | #2 |
Re: Manual choke to Electric choke
should be easy all you need is ignition power wire to power it when the key is on
10-04-2012, 03:13 PM | #3 |
Too easy. You just need a 12v source that's on when the ignition is on.
10-04-2012, 03:43 PM | #4 |
I guess the next question is how hard is it to add a 12v source?
1970 Chevy C20 |
10-04-2012, 04:08 PM | #5 |
It's literally as simple as finding a wire that's on only when the ignition is on and running a splice from there to the choke coil.
If you go to the fuse block, there's a terminal marked IGN. You can run a wire from there if there's not something closer under the hood. |
10-04-2012, 04:11 PM | #6 |
If the carb has a manual choke & you want to change to electric, Edelbrock has a kit to change it over.
10-04-2012, 04:15 PM | #7 |
Great info everybody you have given a great start on converting "The Beast"
1970 Chevy C20 |
10-04-2012, 04:18 PM | #8 |
Parts and more parts
I would suggest looking at the Edelbrock AVS carbs. They are a 650 CFM carb and fit the needs of a truck much better than the 600 does.
Frank |
10-04-2012, 04:19 PM | #9 |
I have a 600 CFM Edelbrock I converted over to electric choke sitting on my engine right now. If I was home I would pull it off and send it to you for a $150 or trade for your 750. I already have a 650 I bought for replacement. But I plan on building the engine up a hair more... If you don't do it before till around the end of January, keep me in mind.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
10-04-2012, 04:24 PM | #10 |
Right now I'm just getting an idea on the conversion and I still have to find a carb. I will you in mind GMCJOE as I'm not sure when I will be doing this. I might get the conversion kit now and that way in the future I can just switch out the carb.
1970 Chevy C20 |
10-04-2012, 07:49 PM | #11 |
I do just the opposite. I buy electric choke carbs and convert them to manual.
10-04-2012, 10:04 PM | #12 |
I have an electric choke on a quadrajet and I am considering converting to manual choke. I can never seem to get the electric choke to work to my liking. In my 67 GMC with 6 cyl I have a manual choke that works excellent and I really like it. You could purchase and install a kit to convert and if it does not work good for you then you could go back to manual choke. Good luck.
