Old 10-04-2012, 05:05 PM   #1
blackesdime
bel air dash?
Just picked up my truck this past Friday ('55). Somebody had cut up a bunch of stuff to make it work on a Dakota frame with almost everything Dakota in it. In doing so, most of my dash has been cut out. I can't seem to find a replacement dash for this truck, but it seems Bel Air dashes are pretty easy to find. From what I can tell in pictures... it SEEMS like it would be pretty easy to make it fit. Am I far off?
blackesdime is offline   Reply With Quote
Old 10-04-2012, 05:10 PM   #2
blackesdime
Re: bel air dash?
(2nd series)
Old 10-04-2012, 05:14 PM   #3
Denee007
Denee007's Avatar
Re: bel air dash?
I wouldnt know, but I'd like to see your truck and what had been done to the dash! I would think someone here will know!
dne' ; )
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 10-04-2012, 05:20 PM   #4
blackesdime
Re: bel air dash?
haha, the truck doesn't look anything impressive. I bought it in pieces... a "trailer case". It was towed to my house using a flat bed and the bed of my truck... lol. no chassis, no motor, just want i need to build something fun.
Old 10-04-2012, 05:31 PM   #5
blackesdime
Re: bel air dash?
best picture of the dash that i can do for now.
Old 10-04-2012, 05:43 PM   #6
Denee007
Denee007's Avatar
Re: bel air dash?
Wowzers! sure makes it easy to work on "under" the dash! ; )
I found this on a simple search. You need a entire dash patch panel! ; )
I see potential!
dne'
http://www.classicindustries.com/truck/parts/17112.html
Old 10-04-2012, 06:06 PM   #7
Kim57
Kim57's Avatar
Re: bel air dash?
Kabwe put a 55 dash in his build which looks very nice.
The 59 Impala dashes are also an option.
You can also do a smooth dash panel. It all depends on the look you want.
http://www.brotherstrucks.com/prodin...number=SDF5559
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-04-2012, 07:35 PM   #8
Chevette
Chevette's Avatar
Re: bel air dash?
I cut my 56 truck dash out and installed a 57 Bel Air dash. It was very easy to do. Then I recently cut it out and I'm replacing it with a Corvette dash (not so easy). In short, changing a TF dash to a 55 -57 Bel Air dash in not at all hard to do. In order to make the steering column look good, you'll need to change the column angle and raise the hole in the firewall, which is no problem either.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 10-04-2012, 07:36 PM   #9
mr48chev
mr48chev's Avatar
Re: bel air dash?
Are you leaving all of that stuff under the dash or pulling it out and going with a heat/ac system that isn't so bulky?
I'd say you are wide open to put what ever dash you want in it as long as it looks good. Or find a cool instrument panel and build around it.
If you decide to cut that dash out completely, leave enough of it to fasten the replacement dash to. That makes things a lot easier all around when putting the new dash in.
Old 10-05-2012, 09:01 AM   #10
blackesdime
Re: bel air dash?
Very helpful!! Gives me something to look into.
Old 10-29-2012, 09:27 PM   #11
bearlakecustoms
Re: bel air dash?
you should have left the dakota stuff, and the plywood dash
bearlakecustoms is offline   Reply With Quote
Old 10-30-2012, 12:09 PM   #12
bowt1ed
Re: bel air dash?
Sure would like to know where those 55 Bel Air dashes are easy to come by at. I can't seem to find one at all around here for my 2nd series!
bowt1ed is offline   Reply With Quote
Old 10-30-2012, 01:28 PM   #13
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: bel air dash?
I got mine from ebay.
Kabwe is offline   Reply With Quote
Old 10-30-2012, 09:24 PM   #14
Rude Dude
Rude Dude's Avatar
Re: bel air dash?
Here is one not mine
http://www.ebay.com/itm/1955-56-CHEV...sories&vxp=mtr
Rude Dude is offline   Reply With Quote
