10-04-2012, 09:05 PM | #1 |
blast media... what to use
I bought a sandblast booth today, less than 1/2 price at Princess Auto. It has a good sized blasting chamber. What is the best media to use. I will be blasting control arms and such, but will also be blasting more delicate stuff as well. Should I use glass beads, sand, crushed walnut?
I may have posted this in the wrong area, but I know you guys look here all the time...
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
10-04-2012, 10:04 PM | #2 |
Re: blast media... what to use
I like glass beads if there's not alot of rust or paint buildup. It's really nice on aluminum and other soft metals. Alot less dust than sand as well.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-04-2012, 11:44 PM | #3 |
60-66 Nut
Copper slag works good on parts that are just going to be painted or powder coated. It is less $$ than glass beads also.
10-05-2012, 01:30 AM | #4 |
I've always used glass bead at work. It's easy on the metal but with a decent pressure you can get a lot of the paint off with a little patience. Unless time is of the essence, the n I use aluminum oxide. That stuff is much harsher though and will leave a more severe surface profile. Walnut shells are great also
This might help you a bit http://www.kramerindustriesonline.co...ting-media.htm
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
10-05-2012, 10:05 AM | #5 | |||
10-05-2012, 11:02 AM | #6 |
I prefer garnet. It's a good all-around media, and if you're doing something soft, just turn the pressure down. Works great on rusty parts, too.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
10-05-2012, 12:15 PM | #7 |
Thanks, garnet, like certain sand paper is garnet... different coarse garnet available I presume, auto body supply shops good place to look for garnet?
10-05-2012, 02:25 PM | #8 |
UCA63
When I put mine together I used the tape they supply AND silicone to ensure its leak free.
My first run I ran silica sand but switched to aluminum oxide hoping it would cut down on the dust and cut faster (and it did). if I did it agian I would deviate from the instructions a bit !. install gloves before panel assy 2. install glass before assy 3. if you have the light option install it too It was a pita installing it all after the box was together...of course I siliconed it all,so I didn't want to take it all apart. Another hint for cutting down on dust ....wire wheel or wire brush as much rust/crud off as you can before hand. Hope this helps T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
10-05-2012, 02:36 PM | #9 |
SIR
...C4 ..but that's just me...
66long low fleet http://community.webshots.com/user/LVNR66 |
10-05-2012, 03:01 PM | #10 | |
Thank you "SIR", good bit of education here for me.
10-05-2012, 05:34 PM | #11 |
I have used garnet for years. It works well, leaves a great profile for powder (I don't do paint) and is cheap.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
10-06-2012, 11:07 PM | #12 |
I use aluminum oxide in the cabinet. Lasts way longer than other media, but only use it with steel parts.
Used copper slag in the portable blaster. $14 per bag from OK Building Supplies if you have them out there. It's called Kleen Blast. Posted via Mobile Device
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
