A day late and $1 short...
So, I have been driving my recently "completed" 5.3L swap and it is giving me an issue. When it gets warmed up it wants to die when I come to a stop. It also dies or the idle drops very low after revving it. The mixture seems a little rich also. Has anyone had this issue?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 10-04-2012 at 11:24 PM. |
Re: 5.3L Swap Idle Problem
Do you have a VSS hooked up?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I do, but I noticed tonight that the speedo wasn't working. I wonder if it came unplugged... How does it affect idle?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 10-05-2012 at 12:34 AM. |
It let's the PCM know when you're slowing down, without it it will take a.second for the PCM to adjust and will cause a stalling problem. Usually more noticeable on rapid decel. If this is a new problem, not int that has always been there, and your speedo used to work then it probably is your problem.
I didn't see the part where you said it will stall after revving it. Could be an IAC problem. Is it DBC or DBW? Have you checked your fuel pressure? Posted via Mobile Device
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 10-05-2012 at 02:37 AM. |
I was planning to check the fuel pressure after work today, what should the fuel pressure be with and without vacuum? I will check the VSS pigtail also. Thanks for the info!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Should be somewhere around 58psi . Unhooking the vacuum line from the rail mounted pressure regulator will make it go up but not sure how much.
Read a write up this morning that said the 99-02 5.3L with a return style fuel system should be 50-55 psi and around 60 psi with vacuum romoved. You are saying 58 psi... I guess I will see what mine is and go from there, I appreciate your help.
Truck and auto performance nut
if its dbw.....seen dirty throttle bodies cause this on dbw systems.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Mine is DBC.
Well, fuel pressure is 55psi with vacuum and 61psi without vacuum. The VSS is functioning correctly, but the reading on the electronic speedometer is very low. It reads 10 mph when the truck is going 40mph per a GPS. I suspect that is due to differences in my gear/tire configuration vs the original truck. I also cleaned the throttle body to eliminate that as a potential problem. I have a hand held scanner and it only gives the code P0650 for the Malfunction Indicator Light, which I new was not hooked up correctly. I have an appointment with a friend of Hart_Rod's who is an experienced LSx tuner, maybe he can fix it with a new tune. I don't know what else to do...
do you have the IAT and temp sensors hooked up? 02 sensors?
are you runing SD or MAF tune, OL or CL? is it 100% stock? If not what mods have you done to the setup? are the pcm and motor from same donor vehicle? So many things it could be lol, your friend that is a tuner should be able to nail it out! GL man! Last edited by 1BADLS1tuner; 10-06-2012 at 12:11 AM. |
Yes the IAT, Temp, and O2 sensors are hooked up. It uses a MAF and has O2 sensors so it is OL... (when warm I assume). It has the GM "hot" cam upgrade and that is all. PCM and engine are from the same truck.
I get what you are saying, I am in research mode collecting info (final drive ratio etc) about the truck so I am ready for the tune on Sunday. Sunday! Sunday! Sunday! Be there!
#13 | |
![]() Youll get it figured out! ![]() |
meowMEOWmeowMEOW
I didn't see which trans you were running, but assuming its an o/d trans, its possible the bog on deceleration could be related to lockup.
I had a misfire count issue causing the lock and unlcock to screw up on the overdrive. If it doesn't unlock properly on decel, the truck kind of stumbles and trips over itself, sometimes causing it to bog or die if it doesn't unlock fast enough to "catch" itself on the way down. Tuner fixed it as part of a misfire count issue in the pcm.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#15 |
Had the same problem...if its running rich then it will run 25% richer to account for whatever the problem or code the ecm is having. I went to have a complete scan and my fuel pressure was 10% lower than what it was supposed to be in order to match what the current programmed specs were on the ecm. Runs like a dream now..no more stalls or? wasted fuel....also if it is running a code and dumping the extra fuel at it its fowling up ur plugs and 02 sensors....
Posted via Mobile Device |
#16 |
Had this same problem when i first fired my conversion up. Turned out being the o2 sensors. My problem was that i didn't have them fully in the exhaust stream since i didn't have my exhaust hooked up (just dangling on the exit of the collector). I'd start the truck up, it'd idle just fine, and then slowly loose rpm as it got warm, and then go extremely rich. It'd sound perfect if i gave it a little pedal but would die when i'd let off. I know you have your o2's hooked up into the exhaust stream, but based on what i saw with mine and comparing symptoms, i'd guess you've got something going on with your o2's. Not to mention i've had a few fuel regulators go out, one went low pressure and the other went high, and i never had idling when warm problems, i would just notice the acceleration would lag when it went low pressure and it smelled rich when it went high pressure. So once again, i'd guess o2's.
#17 |
My combo with a T56 did this as well. I didnt have VSS hooked up. After I hooked it up and calibrated it to read correctly the problem went away.
#18 |
My VSS has been hooked up the whole time. How did you calibrate it?
