Fuse help.
This might be a really stupid question... When it comes to electrical and cars I am lost for the most part. On a 76 chevy k10 what size amp fuse goes in the accessories fuse spot. I can't find it in my manual or online.... and would that be the problem with why my deck isn't working?
1976 k10 2003 reg cab 1500 Gig'em Aggies ![]() |
Re: Fuse help.
is the fuse blown or what
Re: Fuse help.
Yes the accessory fuse is blown. The light in my cabs not working either if that helps
Re: Fuse help.
if the fuse is blow find out why it is blow and fix it first, if u keep replacing it it will blow and might mess up your wiring. but put a 10 in and see if it work that will tell if the stereo in on that fuse if not u need to case the wire.
Moderator
![]() Join Date: Oct 2008
Re: Fuse help.
According to the wiring diagram the ACC FUSED position is a 20amp fuse.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: Fuse help.
I'll post the fuse block once I get my hands on a computer. It tells you what amps to use and also what fuse powers what. And like hatzie said its a 20 amp fuse.
1978 big ten 350/350:chevy |
Re: Fuse help.
Thanks guys. I took out the deck and was looking at it and all the wires look fine. So I'm wondering if it powers the cab light, cig lighter and radio. But I'm not sure how I should go about troubleshooting it.
Re: Fuse help.
I pulled out the blown fuse and its a 5 amp fuse. Could that be the problem that the fuse just wasn't strong enough?
Re: Fuse help.
hopes this helps and ya put in a 20amp fuse
Re: Fuse help.
the reason i said a 10 amp fuse was, to see if the wiring was okay. if there is a problem it will blow when u turn something on. that why u can see if the is a proble with each thing on the fuse. if u turn on all the loads it will blow but if u turn one thing on and off u can see if if there is a short or anything. then u can see what fuse it will take.
Re: Fuse help.
Thanks for all the help. My dad told me to throw a 5amp in there and I did and it works fine.
