Timing on an 87
Ok tell me how to set the initial timing of this 87. It's computer controlled so, what I need to know is, if I remove the distributor and reinstall, ow do I set the initial. What do I set it at.
2004 Silverado Crewcab (Dark Spiral Gray) |
Re: Timing on an 87
I set my 87 timing to factory spec. With the single wire on the driver side firewall unpluged. You set the timing @ 0 degrees. Mines a 305 v8
Posted via Mobile Device |
#3 | |
![]() Join Date: Apr 2009
Re: Timing on an 87
![]() Desert |
Re: Timing on an 87
you can set the timing at 1-2 degrees above zero
i would not go much more Listen for pinging ... here in denver every TBi i tune i go for 3 degrees and it does make an improvement |
Re: Timing on an 87
It is a brown wire if you cannot tell from pic
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Re: Timing on an 87
Ok that was my question, was there a single wire that has to be disconnected. Thanks, that's what I needed BTW, mine is a 5.7
Re: Timing on an 87
Thanks, I didn't have time to mess with it today, but I did PRESSURE WASH THE UNDER NEATH AND THE ENGINE COMPARTMENT. was pretty clean anyway. I need to get some picture up of it
Re: Timing on an 87
Ok so I got a 87 with a 350 and tbi and what you guys are saying is that I have to disconnet that brown wire to set the timeing even though the distributor is electronic.
Re: Timing on an 87
Yes, it's just disabled the computer so the base timing can be set. Then you hook it back up and the engine takes over
Re: Timing on an 87
Ok thanks.What would happen if you set timeing with out unpluging the brown wire.
Re: Timing on an 87
the timing wouldn't be right, with that connected the computer is adjusting the timing even at idle.
