Old 10-07-2012, 12:01 PM   #1
jlc72
Newby needs wheel BS help 15x10/12
Well, looks like I found the right place.. I have a 67 SWB fleetside that I'm trying to order wheels for. The truck has a 4/6 drop and my back tires are MT P315 60 15 drag radials. I haven't purchased my fronts yet but figured some 15x7's with 3.5" BS and some 245 60 15's.
Was thinking a 10 or 12 rear wheel just don't know what spacing to get to keep them from rubbing the wheel opening.
jlc72 is offline   Reply With Quote
Old 10-07-2012, 12:45 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Newby needs wheel BS help 15x10/12
Welcome to the board!
Does your truck have the original '67 6-lug rearend?
Keith
Convert to disc brakes.
Old 10-07-2012, 01:08 PM   #3
1LIME69
1LIME69's Avatar
From experience I wouldn't go any less than 7" of backspace with a 6" rear drop. I have 20x12's with a 4" rear drop and it would hit the outside inner fender if it was 2" lower.
"The Ultimate Sleeper" 69' SWB, Holley EFI 525 ci. BB, TH350, 3.73 Eaton posi/Moser axles, 1350 diveshaft, Vintec's 20"x8.5" and 20"x12", OPP windows, CPP rear coilover conversion
1LIME69 is offline   Reply With Quote
Old 10-07-2012, 01:21 PM   #4
jlc72
Thanks for the reply. What is your backspacing on your 12's?
Old 10-07-2012, 01:20 PM   #5
jlc72
Thanks Keith!
It is the original housing but we replaced the axles with Dutchman 5 lug replacements. And the front is a Early Classic 5 lug disc brake conversion as well.
Old 10-07-2012, 01:22 PM   #6
jlc72
I could go with 10" wheels if I had too
Old 10-07-2012, 01:24 PM   #7
lolife99
lolife99's Avatar
What tire did you plan to run with the 12" wheel?
The same 315?
Keith
Old 10-07-2012, 01:32 PM   #8
jlc72
The same 315?
Yes same tire either way. I already have them.
Here are the specs I just copied from Jegs.
Tire Compound: R2
Tire Overall Diameter: 30.0''
Average Roll Out/
Circumference: 94''
Tire Tread Width: 11.9''
Tire Section Width: 12.9''
Wheel Diameter: 15''
Spec Wheel Width: 9.5''
Approved Wheel Widths: 8.5-11.0''
Tire Weight: 39.0 lbs
Old 10-07-2012, 04:47 PM   #9
jlc72
Anyone else have any info?
Old 10-08-2012, 02:50 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Lowlife99 hit you with some good stuff. Take it to the bank.
On my '69, which has the same rear end as your truck did when new, I put a15x10 on it with a 5-inch backspace. It fits perfectly in the wheel well. The front is a 15x8, with a 4-inch backspace and it also sits perfectly. Here's a pic that might help. The first pic is from the side (as you can tell). The 2nd pic is not showing you much, but it is what you don't see that is important, namely the tires.
Member Nr. 2770
Old 10-07-2012, 01:23 PM   #11
lolife99
lolife99's Avatar
Since you have the early rearend housing that is narrower than the 71-72 housing,...
I would use a 4.75"-5" BS with a 10" wheel.
And 2" more with a 12" wheel. (6.75"-7" BS)
Keith
Old 10-08-2012, 04:12 PM   #12
Fldawg
Fldawg's Avatar
hey loray, what size are your rear tires
Fldawg is offline   Reply With Quote
