10-07-2012, 05:54 PM | #1 |
mysterious Tranny Question-Please Help.
I went to check my tranny fluid on the 700R4 I have after the engine was warmed up and running and I cannot tell the level. The dipstick has xxxx marks and they definitely have fluid in them because I am able to wipe them dry but there is not fluid on the stick as prominent as there is with oil. I am very careful taking it out, keeping it from hitting the sides and keeping it level and when I do turn it vertical a drop comes off but I am not sure if I am reading it correctly???
There is so little of an amount on the gauge part of the stick. A little history, It is shifting great right now but when I installed it last year it would come out of first gear pretty hard, like it had a shift kit. It is shifting very smooth right now. It has a leak somewhere but not a lot comes out. I just started using it as a daily driver 2 weeks ago. If these trannys are low on fluid do they shift smoother? Am I reading the stick correctly? Thx for the help. |
10-07-2012, 07:06 PM | #2 |
20' Daredevil (Ret)
Re: mysterious Tranny Question-Please Help.
Try sanding the lower part of the stick in a crosshatch pattern. It makes it easier to see the fluid level.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-07-2012, 07:17 PM | #3 |
Rub the cross hatched area with soap stone and recheck the level, the clean fluid will show up better
10-07-2012, 08:00 PM | #4 |
Will d, thx guys. I can see fluid in the xxx'x just not above that level. I just don't want to run her dry. I think it was originally overfilled. They have a spot where excess fluid is expelled on the tranny right?
10-07-2012, 08:13 PM | #5 |
Yes, They have a vent, It would have to overfilled by over a quart of fluid to come out the vent. I overfill mine buy 1/2 quart with the trans HOT. Comes out to read at the max full line when cold.
10-07-2012, 08:48 PM | #6 |
good to know, thanks.
