Old 10-07-2012, 07:48 PM   #1
kcfirstbuild
Engine Ground Question
Is it ok that I grounded the engine using the transfer case bolts then to the frame ? I don't want to use the valve cover bolts and I dont have any threaded spot on the back of the heads.
kcfirstbuild is offline   Reply With Quote
Old 10-07-2012, 09:03 PM   #2
Lee H
Lee H's Avatar
Re: Engine Ground Question
I use one of the started bolts.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-07-2012, 10:23 PM   #3
truckster
truckster's Avatar
It should work, as long as your ground strap is heavy-duty enough. The trans bolts to the engine and the transfer case bolts to the trans, so you have metal-to-metal contact all the way through.
truckster is offline   Reply With Quote
