Old 10-07-2012, 08:40 PM   #1
durty harry
durty harry's Avatar
Temp sending unit
Put a set of new Vortec heads on now I need to get a temp sending unit .
The one out of old head is 3/4 threads and the vortec is 1/2 .
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 10-08-2012, 09:30 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Temp sending unit
Go to a hardware store. You can find a brass fitting to fit the 1/2. An aftermarket sensor with a spade connection will work. I use one on my ZZ4 aluminum heads. Sorry don't know the part numbers. www.jegs.com or www.summitracing.com will have what you need. www.painlesswiring.com is where I ordered my electric fan probe.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-09-2012, 06:42 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
thats what I did
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-10-2012, 04:29 AM   #4
chengny
chengny's Avatar
"The one out of old head is 3/4 threads and the vortec is 1/2 "
If I read it right, he means that the sender he has is 3/4" NPT and the hole in the cylinder head is only 1/2". It's already too big - a bushing won't help.
You'll need to get the 1/2" size sender or sometimes the coolant sender hole in the other head is bigger (if you don't mind moving the wire). If it is the right size, put the one you have in the other head.
It is also acceptable to use either the thermostat housing (if there is a free hole) or some people even use an available hole in the intake manifold.
chengny is offline   Reply With Quote
