Front sway bar delete?
Who has removed/deleted your front anti sway bar?
I need to replace my sway bar bushings on my '81 and was wondering If anyone just removed the whole thing? I have 4" superlift springs. Thought I saw a quick disconect kit somewhere while surfing |
Re: Front sway bar delete?
Unless its a off road only truck keep the sway bar you need it.And they do make disconnects http://offroaddesign.com/catalog/swaybarkit.htm
#3 | |
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
I just put the ORD links on my K30 and freshened up the front springs this past month and it rides much nicer now. I have about 5"of lift. the sway bar limits the suspension movement and beats the crap out of your bushings after you lift it, just having those links allows the suspension to move as it needs and the sway bar can still do its job.
I will probably replace the release pin they give you with a bolt/nut in the future as I don't plan on disconnecting it, the pin and lock clip will probably start deteriating and come apart after the first winter anyway (this truck is my daily driver). You definitely don't want to eliminate it completely unless you were going to do off road only. Try out the links, I think you will like it. |
take it off, see if you even notice its gone.
You don't need it, it's just tricky if you have to turn quick or take a turn little to fast. I did it to a couple trucks. Will be fine while you replace the bushings.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
