Free parts with pics this time. lol
I been blabbing about good free parts with no pics. Well here they are. Brake booster and pedal is already spoken for. I also have the driver stepside fender with spare tire brackets. I am looking for a regular stepside fender to replace it. Also have heater assembly as well. All appear to be in good shape. I have the spare too. This truck hasnt been on the highway for about 5 yrs but the owner did drive it around his property. As you can see it isnt bad. I just dont want to scrap good stuff. Pics show condition before and after I pulled from my frame.
1. front and rear axles and suspension parts, spare tire carrier(fender), heater assembly. Last edited by thump16; 10-08-2012 at 10:51 AM. |
Re: Free parts with pics this time. lol
So what exactly are you giving away? The entire rolling frame or the axles? I love those wheels...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
better pics
Hollister Road Co.
What is that frame from? Its the first bolt in rear engine mount I've seen
its my 56 frame. the engine mounted from front to bolts.
I would love to have the rear axle housing (including differential), axle shafts and rear wheel housings (assuming it's a six bolt).
Posted via Mobile Device |
Are those wheels available at all??
Hollister Road Co.
The area circled is what I was asking about. I have never seen a bolt in member for that spot. Its always riveted to the frame
Hollister Road Co.
OK I see you have a hydra-matic truck so that explains the drop member
i learn something new everyday on this forum
i've owned 6 tf trucks since 1973 had never seen a bolt in x-member either hydromatic explains it
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Hollister Road Co.
I've never seen it either till this one but i have never actually seen a stock automatic 3100 truck first hand, thinking about it you couldn't the trans out if it wasn't that way
Engine & trans came out with no troubles. If somebody needs this trans mount(3) pieces. Its free. I am not gonna trash any parts. They will get a home in my attic
Did you say you had a side spare tire bracket??
any engine parts throttle linkage ?
#15 |
Location: Hickory, NC native, but stuck in Valdosta, Ga
I want the spare Tire bracket and the HUB CAPS!!!!!
#16 |
My first TF truck was a hydramatic. I was 15 when I bought it and had little background with cars. I spent a huge amount of time trying to figure out how to trade out the 235 / auto for a 283 / standard. I just couldn't figure out how the engine mounts were supposed to go because the crossmember pictures in the service manual weren't bolt in and mine was. None of the old timers I asked remembered it being bolt in either. I actually ended up buying a '58 283 + 3spd truck so I could use the frame under my '55 big window cab.
#17 |
I am keeping my frame. I just chopped it up to accept the PB Dropmember.
#18 |
PM Sent
