Old 10-08-2012, 02:21 PM   #1
flyingtim01
'71 K20 Growling/Grinding noise
Hey Guys,
Saturday morning I got into the truck to go pick up a new dishwasher. Halfway there, before I even got on the highway, I started to feel this growling/grinding noise from under the truck as soon as I hit 35-40 mph. Got on the highway, and it feels like it mostly went away around 60-65. Got back off the highway, and slowed to 35-40, and it came back. Loaded the truck (after it sat for about 30 minutes) and it didn't immediately come back. Did 40 mph or so for a while and it was quiet, then I hit a bump and it came back. Got back home and parked it and got to work on the dishwasher.
Sunday morning, I went and picked up a cord of wood with it. As soon as I got onto a main road, the growling came back. Loaded it with a full cord of wood, and got it back out onto the main road, and the noise was gone, or at least severely diminished. (No insulation/carpeting left in the cab, it's pretty loud even when it's quiet)
Just to run down the list of obvious things: U joints are all greased (all of them), axles have plenty of oil, as do the tranny (SM465) and transfer case (NP205). It doesn't feel like a vibration from a tire. After I parked the truck on Saturday, I went around feeling the hubs. The only one that was warmer than I thought normal was the right rear (full floating eaton) so I'll have to take a look at that. Isn't that bearing oiled directly down the tube from the pumpkin?
Anyway, the grinding/growling seemed to be coming much more from under my feet, so I was thinking a front wheel bearing, though nothing was hot in the front, and I've never known a bad wheel bearing to get better the faster you went.
It is odd that the noise almost completely went away when fully loaded with a cord of wood though, so this afternoon I'm going to crawl underneath and see if anything is contacting the driveshaft or something along those lines. I wonder what would be different when the suspension flexes (it seemed like going over a bump triggered it to start with, and then when loaded down it goes away) so I guess I'll have to eyeball everything. Any suggestions?
flyingtim01 is offline   Reply With Quote
Old 10-08-2012, 03:19 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: '71 K20 Growling/Grinding noise
Yes, it is.... and that's the only real answer I can give you about anything right now.
I wonder if you might have a u-joint going bad -- they can, even if regularly greased. An internal passage can be blocked resulting in dry bearings. Look for any sign of red powder (rust) around each bearing cap. Moving them by hand isn't necessarily a good test, either. If possible, put it up on a hoist and have someone run it up to 35 or so on the speedo and look for vibration at each u-joint.
Other possibilities are bad bearings in the tranny or t-case.... not sure how you could easily isolate those though.
Quite a mystery you have for now....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-08-2012, 04:10 PM   #3
flyingtim01
Thanks Stocker,
Just a little background on the truck. Its a rack body, and was initially a power company truck when new. There's a Braden PTO winch and massive bumper, the apparently used it to pull line with. After that, it was purchased to tow a horse trailer and haul firewood. The guy I bought it from was the third owner and last registered it in 2000, and did just about nothing with it. From what I can gather, the truck basically sat in his yard and when he needed to pull something (like one of his other projects) that's when the truck would get started and moved 50' and parked there for another large amount of time. So when I got it, it needed a lot of work. It hadn't been on the road for at least 10-15 years. I replaced the pads, rotors and shoes, put on a new MC and booster, replaced the parking brake cables, swapped out the cast iron intake and two barrel for a Qjet and an Edelbrock Performer, gave it new tires, did a once over on the electrical system, replaced some brake lines, changed the fluids, and greased everything, including the wheel bearings. I also swapped out the old Spicer hubs for a set of Warn hubs.
It seems to be doing really well, that is until this weekend. I was thinking that I should be replacing the U joints anyway, just because I don't know how old they are, and they're relatively cheap. I suppose that could be it, since I've been driving it, on and off I can feel a slight wum-wum-wum kinda vibration around 35 mph, though I've always written it off as unbalanced tires. I'll do a visual check of the U joints, but I think I'm going to plan to replace them, at least the two in the rear, ASAP.
Old 10-08-2012, 04:59 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've always thought of tire unbalance as more of a shake (or low-frequency vibration) and bad u-joints as more like a high-frequency vibration...... possibly what you are describing.
Good luck, if you throw new u-joints in, I hope that fixes it. Keep us posted!
Your truck sounds like a real workhorse. I retired from telecom construction and some of our rigs got a pretty good workout at times.... same with the power company trucks!
Incidentally, my truck also has a Q-jet (OEM) on an Edelbrock 2101 Performer that I got when my stock cast iron intake cracked. Pretty good setup for all-around use IMO.
- Mike -
RIP El Jay
Old 10-09-2012, 11:25 AM   #5
flyingtim01
Didn't get a chance to do the visual last night, but it's on the list. And I am going to do the U joints just because, so I'll report back on both those fronts.
The truck is definitely a work horse. I'm pretty sure the original 307 has been replaced by a 350 from a '75 truck. I haven't managed to get at the casting number yet, but the stamped number on the passenger side of the block at the front of the head seems to bear that out. The cab is shot...but it's also a replacement, it's a '72 cab. Other than that, it doesn't look like it was beat on too much by the PO's.
The PTO and winch is somewhat of a mystery to me, though. I wonder if it was dealer installed, or if the power company installed it? The Braden LU2 winch came on a lot of Dodge trucks of this era, so I'm wondering if the power company had a wrecked Dodge with that setup on it, and swapped it over to this truck. It doesn't look homegrown at all, with the correct frame extensions and massive bumper. I don't think I'll ever know for sure, but I doubt the dealer would have installed it this way. All the Chevy PTO winches seemed to have a cable installed in the dash, this one has a lever that sticks up through a hole in the floor.
Old 10-15-2012, 12:04 PM   #6
flyingtim01
So the visual inspection turned up nothing. Nothing seems to be rubbing, no exhaust issues, no driveline issues.
Thinking over the symptoms (aggravated by bumps, worse/louder when truck is empty, much quieter when fully loaded) leads me to believe that it's one or both of the U joints. With the truck loaded to the gills and the suspension compressed, the driveline is a bit straighter, and it stands to reason that the U joint wouldn't be at such a severe angle as when the truck is empty.
Ordered up a couple Spicer 1350's and a couple U bolt kits. Funny, when you look it up on the Spicer website, they say the truck should have two 1310's. Other research I did around says that some trucks have a 1350 in the rear and a 1310 up at the transfer case. I measured mine and both are 1350's.
Hopefully get them changed out this week, and I'll report back!
Old 11-10-2012, 10:48 AM   #7
86c20
86c20's Avatar
if that truck has alot of miles like one of mine i lean towards baerings in the trans. mine when light makes a loud grinding/ wineing sound load it down with about 5k no sound but when you let of the gas and the drive line slaks up. all new u jionts and a replace driveshaft also and still there seems to be comin with high mile 465 that are well used as mine is in a tow truck with some of the dumist drivers there are
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 11-11-2012, 04:03 AM   #8
rjsdad
rjsdad's Avatar
My burb makes that same grinding noise when it hits certain bumps. Sounds like its coming from the front axle and I feel it right under my feet. It will go away either on it's own or if I stop the truck. I haven't inspected it yet but thought the axles needed to be repacked. I'm not very mechanical so I'm not sure.just wanted to let you know you weren't the only one going thru this
rjsdad is offline   Reply With Quote
Old 11-11-2012, 01:38 PM   #9
odog
odog's Avatar
If you are dropping the trans to change the input bearing, you may look at the output shaft. You have to pull the adapter off of the trans side, but it is worth it while you have it out. Just a suggestion
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 11-15-2012, 01:42 PM   #10
flyingtim01
Glad I'm not the only one going through it!
I drove the truck two days in a row, unloaded, this weekend. I locked the hubs in, but left it in 2WD. No noise...at any speed, or over any bumps. Interesting. It won't cost me anything but time to inspect the front wheel bearings...I'm wondering if the driver's side bearing is loose/bad and is allowing the splines on the end of the axle shaft to contact the hub or something else in the spindle area, and now that the hub is locked it, the shaft is supported from the end and not making any noise.
Odog, thanks for the FYI. If it has to come out, I'll be inspecting everything. I suspect something might be out of whack in the adapter as well, when coasting there is a faint clunkclunkclunk sound coming from that general vicinity.
1971 Chevy K20 350/SM465/NP205
Old 04-29-2013, 10:16 AM   #11
flyingtim01
So I just wanted to follow up here, I can't stand threads where the OP never posts up the solution to the problem!
I drove the truck all winter with the hubs locked in, and never experienced the same noise. I started to wonder if maybe I had a bad hub, so I got a stud kit and a rebuild kit for the hubs, and got after it this weekend.
Just as a small backstory, when I wanted to eliminate the old Spicers, I went looking for Warn replacements. I didn't want to spend the $250 on a brand new set of 9072's, so I found a used set off an old Dodge. I think Warn hubs were OE on those trucks for some years. Anyway, I gave them a quick once over 2 years ago when I got them, and slapped them on.
Fast forward to yesterday, with new gaskets, studs and screws in hand, I pulled them off to see if they were damaged/loose, kinda hoping that was the source of my noise in freewheel. What I noticed is that when I put the hubs on, only one side had a snap ring around the end of the axle. The side with no snap ring made no noise, the side with the snap ring is the one that made that grinding noise. So I took the snap ring off and pulled the hub. I went through them both and cleaned them up, didn't notice anything out of the ordinary. So when I went to put them back on, the kit came with new snap rings, so I thought I'd throw them on. It was then that I noticed those snap rings do just about nothing in there. The snap ring on the back side of the lockout keeps the internal hub from sliding outwards, and in addition, the snap ring was way loose in the groove on the shaft. As in, I didn't even need snap ring pliers to put it on and take it off. So I left them off. I don't remember when I took the old Spicers off, maybe it made more of a difference with them that it does with the Warn hubs.
Anyway, I'm thinking that because that snap ring was so loose, when the hubs were disengaged and freewheeling, that ring got loose and dislodged (like when I went over a bump) and then started grinding against the inside the hub. I didn't see any damage in there, but the snap ring was a little twisted.
So after it all went back together (looks great with the new studs) I took the truck out and hopped on it a little. Even after a couple trips up to 65mph and back, still no noise.
So I think I got it fixed. Thanks for everyones help!
Old 04-29-2013, 11:11 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: '71 K20 Growling/Grinding noise
Thanks for the update.... and I'm glad the noise finally gone!
- Mike -
RIP El Jay
Old 02-10-2017, 06:51 PM   #13
oski6754
oski6754's Avatar
Hey flyingtim01,
I'm having the SAME issue you described. Just want to check back with you to see if the snap ring was indeed the culprit?
Regards,
Miles
Miles
1972 GMC Suburban K15 - Custom Deluxe
oski6754 is offline   Reply With Quote
