69 c20 rear suspension swap
Got me a '69 C20, and want to convert it over to 1/2 ton suspension with 5 lugs. A buddy of mine has a partial 88 C10, and I was wondering if I could use the rear end, and springs from it??? I would love to, but know I cant use any of the front suspension from it
Re: 69 c20 rear suspension swap
anyone?????
![]() Join Date: May 2011
the 88 rear end is much wider that your truck. I think 3" (dont quote me). It is also a 10bolt. To make things easy for you and to get the stronger 12 bolt go to a bone yard or check craigslist or the forum and look for a 71 to late 70's 1/2 ton rear and use that. it is wider, it will bolt right in and it will save you allot of effort.
also welcome to the forum!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
Thanks. I already found through google searching, that the rear from 88 and up will be too wide. I dont think I really need to worry about the strength of 10 vs 12 bolt, as I wont use the truck for hauling, nor will it have a big motor. I was wondering though, and just posted the question if perhaps a second gen Camaro rear would swap into the truck. I know it's narrower, and that may be what I want so I could fit wider tires and rims inside the wheel wells. Even if I had to widen the wheel wells inside the bed an inch or two
