05-29-2003, 08:18 PM | #1 |
Florida Key's Member
rear disc brakes ?
well time to redo the rear brakes on my pile what does it take to convert to rear disc on 4x4 12 bolt rear end ???
Craig Wood 1972 SWB Chevy Cheyenne 4X4 Restored stock except 454 (481 cu. in. now) most options Available pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528 Come to florida and visit www.Paradisewatersports.com |
05-30-2003, 03:35 AM | #2 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Some brackets from Speedway Motors, a couple of 75 Camero front calipers, a couple of axle hats and rotors from said company, a good welder, lots of patience. And a brake master and prop valve from mid 70's Corvette. You wont have parking brake, but I plan on using a line lock to lock the rear wheels up. Im in the process of doing this project right now. Will post pics when its finished.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
05-30-2003, 06:47 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I did mine about 1 tear ago.I got a 71 Blazer 4x4 with a 12 bolt in the rear.
Got the brackets and rotors from TSM. http://www.tsmmfg.com/ Master cylinder from a 78 Corvette rear disk brakes from a 84 Caddilac Eldorado I was able to modify the Eldorado rear disk braket that holds the e-brake return spring and make my orig. Blazer e-brake work. You can see all the pic's here
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-30-2003, 10:07 AM | #4 |
I'm pretty sure I saw a conversion kit in Chev Duty's catalogue. Pricey, but might save a bunch of time converting things.
69 CST BB 69 Mach 1 72 C-10 69 Acadian 68 SWB Chevy |
