10-10-2012, 10:34 PM | #1 |
Help with tire/lift fitment q78 tires
Im looking at a set of q78 buckshots for my suburban I just bought. However im not sure what they will require for lift. They are a taller skinnier tire and with the right offset im hoping they will fit. The PO of my 70 k20 burb said hes pretty sure it was a 4" lift he put on it some years ago. Ive gotten mixed readings from measurements as far as hub to fender. Maybe the trucks and burbs were somehow slightly different. I dont think so. When I measure from the center of my front hub to bottom of fender I get 25 3/4 inches. The rear sits almost 2 inches lower than the front from the ground. So it sags and it already has a 2 inch block under the rear. Maybe it was a 4" and is wore out or? If anyone has a 67-72 with simliar size tires or buckshots please post a pic too.! Thanks
10-10-2012, 11:18 PM | #2 |
Re: Help with tire/lift fitment q78 tires
If you have a 4" lift,they will fit for sure.
10-10-2012, 11:20 PM | #3 |
Thinking about running them on steel fords, or k2500 rims. So Im sure offest will be fine. I just need to figure out the lift so I can buy them before theyre gone! Thanks for the feedback.
10-11-2012, 01:52 PM | #4 |
Good luck, They quit making the old school Buckshots a couple years ago.
I wish they did, cause I need some P's.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-14-2013, 06:14 PM | #5 |
You can look on fleabay. They have some new ones on there that were mislabeled. They are under blem tires. Brand new tho!
