Old 10-11-2012, 07:49 PM   #1
hondizzle
hondizzle's Avatar
Vin on frame
I was told that the vin number wasn't stamped on the frame rail pre 1971 on 2wd and 4wd is this true? I'm looking at a 1970 and the body's vin is a 4wd I'm just curious to know if the frame had a vin stamped on it to see if its a real 2wd frame or a conversion. Thanks for the help
hondizzle is offline   Reply With Quote
Old 10-11-2012, 10:33 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Vin on frame
Mine is easy to see on both side of the frame, about even with the door.
I've heard, but have not looked, that the VIN is stamped somewhere around the steering sector as well.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-12-2012, 10:43 AM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Vin on frame
I will take a peek this weekend on my trucks. My 72 has it stamped in two spots. I will try to see if it's also stamped in the same spots on my 70 frame.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-12-2012, 07:26 PM   #4
hondizzle
hondizzle's Avatar
Re: Vin on frame
Ok cool thanks guys
Old 10-12-2012, 09:04 PM   #5
rsavage
rsavage's Avatar
Re: Vin on frame
I have a 70 shortbed 4X4 and the partial VIN is stamped on the frame. It was there also on the 70 Burb I recently sold and it is on my 71 Blazer 4WD.
The entire VIN is not stamped on the frame just the last several digits of the VIN. Usually found on the top of the driver's side frame between the steering box area and firewall. This isn't going to tell you whether the Blazer was a factory 2 wheel drive. Your VIN will start with a C if it was a 2wd and a K if it was a 4wd. For example, KE181sXXXXXX would be a 4wd V8 Blazer (the 2nd letter "E" a V8, the 4th number"8" denates a Blazer). The XXXXXX would be found stamped on the frame. If it began with a CE it would have been a 2wd V8. CS would be a 2wd 6 cylinder. I have only personally seen a couple 2wd Blazers. The couple that I have seen were originally factory 6 cylinder vehicles by their VIN (CS). If the partial VIN on the frame matches your VIN tag then it would have originally been a 4WD.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-13-2012, 01:31 AM   #6
PHAT TONY
PHAT TONY's Avatar
Re: Vin on frame
2wd frames are different from 4wd frames; wider on 2wd ahead of the diff for coil springs (4wd are leaf springs).
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-18-2012, 03:44 PM   #7
blazin71K5
blazin71K5's Avatar
Re: Vin on frame
I have my 71 2wd stripped down to the bare frame and can't find a vin anywhere on the frame even in the usual places was wondering the same thing.
71 2wd k5
67 Nova
blazin71K5 is offline   Reply With Quote
Old 10-18-2012, 04:38 PM   #8
29od1
Re: Vin on frame
I would say if the partial VIN's are not there, then someone ground them off. Every frame that came off the assembly line should have had 2 partial VINs stamped on the LH side top of the frame. One was by the steering box and the other was located basically under the drivers seat.
There are a few documented cases where the partial frame VIN and the VIN plate on the body didn't always match from the factory because the body and frame got out of sequence on the line. But they were usually only off by one digit.
29od1 is offline   Reply With Quote
Old 10-20-2012, 06:28 PM   #9
DustinU
DustinU's Avatar
Re: Vin on frame
As mentioned above, my 69 has the partial vin stamped on the frame by the steering box.
DustinU is offline   Reply With Quote
Old 10-20-2012, 08:19 PM   #10
blazin71K5
blazin71K5's Avatar
Re: Vin on frame
Finally found it between tranny crossmember and trailing arm cross member buried under what looks like factory undercoating that is all over the bottom of the tub and it was correct.
71 2wd k5
67 Nova
