Old 10-12-2012, 12:01 AM   #1
c10boob
c10boob's Avatar
1971 Horn
So I just purchased my first 67-72 style a couple weeks ago, and am still learning a lot about it.
The horn button on the steering wheel does not work, however, pulling the turn signal switch forward honks the horn.. so is there an explanation for this other than someone screwed with the wiring?
c10boob is offline   Reply With Quote
Old 10-12-2012, 12:03 AM   #2
SeeTen
SeeTen's Avatar
Re: 1971 Horn
If it's an aftermarket steering wheel, they may have done it on purpose instead of just wire it up to the horn cap. If you have the original wheel, you can yank it off and see how crazy the wiring is under it - something metallic may have busted off, is rubbing etc. and it just happens to do that.
My advice - don't mess with it and be glad you still have a horn!
SeeTen is offline   Reply With Quote
Old 10-12-2012, 12:09 AM   #3
c10boob
c10boob's Avatar
Re: 1971 Horn
Haha good advice, I was thinking the same thing! I HAVE A HORN!
So what's the original function to pulling the turn signal switch inward if not to honk the horn?
Old 10-12-2012, 12:24 AM   #4
SeeTen
SeeTen's Avatar
Re: 1971 Horn
Not too sure - considering the bright switch is on the floor. Maybe someone else could chime in here?
Old 10-12-2012, 09:57 AM   #5
cdowns
cdowns's Avatar
Re: 1971 Horn
there is no function for turn signal switch either in or out// it only works up for rt hand turn down fow left
if it moves any other way you have a mounting problem// and if you move it in and horn honks i suspect that it is contacting the horn wire and causing it to ground out as that is what makes the horn work
Old 10-12-2012, 02:33 PM   #6
c10boob
c10boob's Avatar
Re: 1971 Horn
Thanks cdowns, I appreciate the info!
Old 10-12-2012, 11:08 PM   #7
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: 1971 Horn
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 10-13-2012, 05:18 AM   #8
c10boob
c10boob's Avatar
Re: 1971 Horn
Originally Posted by magwakeenercew2jh View Post
Ahahaha! I like the pic! And THAT makes perfect sense, which brings me to this thought: I need a windshield washer assembly.
No, wait.. if I did that then every time I spray windshield washer fluid I would be honking my horn.. hmm, I have work to do!
Old 10-12-2012, 05:01 PM   #9
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 1971 Horn
Could be that the turn signal switch inside the column under the wheel is broken and like Cliff said, it is grounding. Does the turn signal switch seem to function properly when you move it up or down?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
