Old 10-13-2012, 10:14 PM   #1
robert_63
robert_63's Avatar
fuel pump for 87 tbi tank.
Just scored a pretty nice FREE!!! 87 longbed for parts, Doin the 5.3 swap in my 85 shortbed, anyone have a part number for an intank pump i can put in the 87 tank?
robert_63 is offline   Reply With Quote
Old 10-13-2012, 10:59 PM   #2
clinebarger
Re: fuel pump for 87 tbi tank.
AC-Delco part# EP376 ACDelco EP376 Fuel Pump : Amazon.com : Automotive ACDelco EP376 Fuel Pump : Amazon.com : Automotive
Use 5/16" fuel injection hose between the pump & sender with clamps!
clinebarger is offline   Reply With Quote
Old 01-25-2013, 11:07 AM   #3
solidaxel
solidaxel's Avatar
Will this tank interchange with the with the one in my 78 1/2 T.
What other parts do I need for a 5.3 return fuel system?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-01-2013, 07:23 PM   #4
BigRed76
BigRed76's Avatar
Yes the '87 tank will fit in any '73-'87
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-01-2013, 07:42 PM   #5
Jonboy
Slots go on anything!
Maybe.
They will in respect to the size. 16 Gal. will replace earlier 16 gal., 20 gal. will replace earlier 20 gal. tanks. The only other difference may be in the size of the filler neck and vent tubes. When the filler neck ghanged to the door style, the neck is slightly larger, and will require an adapter be made for the hoses to work.
solidaxel: If you can get the rest of the lines off of the '87 as well, you should be able to use all of it for the return style fuel system. use a union that will take the pressure and mathe the lines at the back of the manifold. That should work great, and be able to use a factory '87 fuel filter as well.
Jonboy is offline   Reply With Quote
Old 02-02-2013, 07:55 AM   #6
solidaxel
solidaxel's Avatar
Jonboy, thanks for the heads up !!!
LS 3 4L70E
