Old 10-14-2012, 11:29 AM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Has anyone extended and stepped their rear trailing arms??
My truck has the same problem that many of your have in that the rear axle/tires sits too far forward in the fenderwell after lowering. I also have a very slight pinion angle difference which doesn't really affect anything at this point. Once my 496 is done, I think those little things might become critical to have dead-on. Finally, I want to take about another inch off the back in ride height. I saw a thread awhile back where a guy did a very neat job of building his own trailing arms out of req tubing. I was thinking what a great way to nail all these areas in one shot with building my own trailing arms. I could make them a tad longer, adjust the rake of the mounting pads and put a 1" step at the point the trailing arm would angle up. I would probably over build them since weight would not be an issue and I would want to make sure they didn't come apart.
You can see from the pics that I have more than enough frame clearance with the C notch. Yes......I will be relocating the rear shock mounts at the same time!!! lol
Anyone ever try this with the step built in??? The goal is to get away from the need for block and I already have 6" drop springs.
prostreetC-10 is offline   Reply With Quote
Old 10-14-2012, 11:43 AM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Has anyone extended and stepped their rear trailing arms??
Sounds like a good idea
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-14-2012, 11:20 PM   #3
crazy longhorn
Fabricate till you "puke"
My longhorn , suffers the same deal I call it altered wheel base) No doubt, you can fab up a nice set of arms , for the old truck.....but if you are building the step into the arm? Are you really gaining anything? Those arms pretty much work.....why mess with that? My thoughts are, put the bucks in that bad AZZ stroker.....sort the azz end out later , if you need to Roast some rubber......but shiny side up crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-14-2012, 11:29 PM   #4
crazy longhorn
Back at you....it looks like the shocks are setting a little too "flat". You might like it better, if they were a little more "straight up"? Not pickin....bad azz ride , how she sets crazyL
Old 10-14-2012, 11:30 PM   #5
prostreetC-10
My Carbon Footprint
The step is to lower the truck 1" at the same time. Did you read the original post?? Are you hitting the sauce again?? lol
That stroker is a whole other mess. I've been looking at Merlin heads as apposed to having my 781s worked. Made the mistake of looking at 496's on youtube. There goes a perfectly good hour. I have a feeling that tonight, as I sleep, I'm going to be chased by 4.250 cranks and 6.385 rods!!! lol
Old 10-15-2012, 12:10 AM   #6
crazy longhorn
Bud, I hit the "juice" , on a daily bassis I run leafs on my old truck/ slappers....she wigles a bit, but pretty much a straight rideMy thoughts, are still.....if those long bars are workin? Let them ponies run! Just my thoughts, take it , for what its worth, it my opinion? Those old trail arms will "hook", & run straight on your 1340 ride.....again, my opinion Have fun, but DAMMIT....SHOW US crazyL
Old 10-15-2012, 09:38 PM   #7
prostreetC-10
My Carbon Footprint
Does anyone know if the LB arms are longer or is the crossmember just farther back? Would be super easy to shorten some longer ones to move the axle back.
Old 10-15-2012, 09:43 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Lwb arms are the same.
Crossmember is just closer to the rear of the cab.
I would install a Porterbuilt tubular trailing arm crossmember.
Position it 1" back and adjust the pinion angle with one of it's four set points.
Plus you get a good way to tuck your exhaust up, by running it thru the crossmember.
Keith
Convert to disc brakes.
Old 10-15-2012, 09:44 PM   #9
lolife99
lolife99's Avatar
Porterbuilt 3" drop trailing arms will get it low.
But lowering blocks will be cheaper.
And you gotta get some shock relocators!
Keith
Old 10-15-2012, 11:03 PM   #10
crazy longhorn
My thoughts in fewer words Honestly, a 1 " block wont hurt, & you can have it cut on a "wedge", to fix the pinion angle. It wont fix the axle being moved foward, due to the drop tho... I think the stock bars will take the "guff", & am just trying to save you some time & money? It should be a fun build crazyL
Old 10-16-2012, 01:07 AM   #11
prostreetC-10
My Carbon Footprint
You guys are missing me here. I realize that blocks are easy and pinion shims are easy too. The original post says that I am going to relocate my shocks so get off my back Mr. Lolife!! LOL
The point was to move the axle back. That requires fabricating new arms which means that requires cutting and welding. I figured that since I was already there....it would be cool to make the cuts to dial in the pinion angle and buy an extra 1" drop at the same time. sheeeeeeesh.
I'm having fun with this thread but must also realize that the answer to my initial question is NO!
Old 10-16-2012, 01:44 AM   #12
Andy4639
Old member
Andy4639's Avatar
Question Re: Has anyone extended and stepped their rear trailing arms??
Just a thought. Why not move the trailing arm mount crossmember back 1" and leave the arms alone. Ok yes it doesn't get you 1" drop but would be a lot simpler I would think.
The "No Limit" shock relocator kit is a nice one by the way.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-16-2012, 11:56 AM   #13
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Another idea to move the axle back would be to make spacers for the actual trailing arm mounts. Cut the rivets, put a steel block between the bracket and the crossmember. Use Gr8 bolts and you should be good to go.
Just a thought.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-16-2012, 02:09 PM   #14
aggie91
I'm just glad to be here!
aggie91's Avatar
I agree with this last post. Put a spacer in between the crossmember and the brackets. Flip the brackets to fix your pinion angle too.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-16-2012, 02:11 PM   #15
aggie91
aggie91's Avatar
Moving the crossmember back works too, BUT there are more rivets to take out and you don't get the pinion angle fixed.
Karl
The LST Challenge:
Old 10-18-2012, 03:13 PM   #16
tubbedII
needs more $$$
tubbedII's Avatar
Just a thought.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-23-2012, 10:37 AM   #17
Hart_Rod
Hart_Rod's Avatar
If you flip the front trailing arm mounting brackets, it will move the rear approximately .5" to the rear.
*Note: this will only work if you have a 4 to 6" drop in the rear.
Hart_Rod is offline   Reply With Quote
