10-15-2012, 02:50 PM | #1 |
67-72 Tach dash
Anyone running the factory tach dash with an LSX 60/80E combo? I've got a awesome 72 dash set up i bought for my truck and i want to use it. And i'm an electronics moron.
Nothing in the search for 67-72. Thanks
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
10-15-2012, 09:06 PM | #2 |
Re: 67-72 Tach dash
10-15-2012, 09:27 PM | #3 |
Re: 67-72 Tach dash
Nothing found, ill keep searching
10-15-2012, 09:33 PM | #4 |
Re: 67-72 Tach dash
I've done it several times, what's your question? what wire to hook it up to?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-15-2012, 09:43 PM | #5 |
Re: 67-72 Tach dash
Depends on what year your PCM is, but generally the 2003 and newer will need the pull up resistor. Also you'll have to change the tach resolution from 6 to 3 in the tune to make it read correctly since LS motors use a 4 cylinder signal, otherwise it will read half of what it's running (on a V8 tach). Other than that, just hook up the ignition wire like it was originally and hook the signal wire, the one that went to the coil, to the tach output out of the PCM, generally a white wire at C2 10, but that may depend on year and application.
10-15-2012, 09:38 PM | #6 |
Re: 67-72 Tach dash
I'm compiling info, and reading up on this swap. But I didn't see any info in the stock tach dash (67-72) being used and if it would work.
When I do my swap I want to use my new tach dash. Posted via Mobile Device
10-15-2012, 10:08 PM | #7 |
Re: 67-72 Tach dash
That's what I was searching for. Thank you.
