Old 10-16-2012, 02:29 AM   #1
Rusty one
Rusty one's Avatar
283 exhaust mani question
I'm rebuilding my 63 C10 283 engine. I've been going thru the parts & I noticed two threaded holes (offset) on one of the front of the exhaust manis. It been awhile since tear down and was wondering what those holes were for. The other exhaust has the old heater flap in it so I believe that goes on the passenger side & the other ( with the offset threaded holes) should go on the drivers side. Any pics of your alt bracket set up will help.
Rusty one is offline   Reply With Quote
Old 10-16-2012, 10:10 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 283 exhaust mani question
the alternator bolts into those, there should be a small stamped steel bracket that goes from those two holes to the head too.
if no one beats me to it I should be able to find a pic for you.
Old 10-16-2012, 11:16 AM   #3
1963c-10
1963c-10's Avatar
Here you go...Several different ones, some are for headers.
1964 Short bed trailer
Old 10-16-2012, 11:27 AM   #4
1963c-10
1963c-10's Avatar
I believe this is the specific bracket though that bolts to the exhaust on the driver side for a 283
Old 10-16-2012, 03:49 PM   #5
Rusty one
Rusty one's Avatar
Wow...none of my alt brackets look like those. IIRC the P.O. put the alt on the passenger side. I think I have the later year alt mount. It's the one that looks like half a clam shell.& adjusts from the top..( will post pics when I get home). My friend loaned me that first bracket...bit it seems to be for headers,not RAM mani. Unless it needs to be spaced away from the exhaust. Anyone have the correct bracket for the 283 alt to exhaust? Thanks for all the pics & help! The people on this forum are great!!!
Old 10-16-2012, 04:03 PM   #6
padresag
you have the later manifold which has the 2 mounting holes in the frt of it
ron
padresag is offline   Reply With Quote
Old 10-16-2012, 04:23 PM   #7
Rusty one
Rusty one's Avatar
ron
Yes...does the alt bracket bolt to it? This PO really messed this up& now that It's all apart it makes it harder to put together correctly
Old 10-16-2012, 04:30 PM   #8
padresag
yes the brkt comes over from the water pump . the bottom part bolts to the bottom hole and the the alt goes between the brkt and the manifold
ron
Old 10-16-2012, 04:46 PM   #9
Rusty one
Rusty one's Avatar
ron
Pictures are great & Thankyou for posting them. Now I see why the P O changed it around...probably didn't have the correct brackets...now to find them ...lol also noticed I have 3 grooves on my crank pulley!
Old 10-16-2012, 04:55 PM   #10
padresag
I also have the 62 amp Delcotron alt mounting that goes with that manifold. the alternator that looks like an old washing machine motor
ron
Old 10-16-2012, 05:13 PM   #11
padresag
3 pulleys should work for wp-alt, p/s and perhaps a/c or it could have been for double belts on w/p-alt, 1 0r 2 groove pulley on w/p?
ron
Old 10-16-2012, 06:55 PM   #12
Rusty one
Rusty one's Avatar
ron
Just did some searching and found that lower alt mount that for a to w/p & ram born mani. Just gotta find that one that mounts to the exhaust studs.
Old 10-16-2012, 07:21 PM   #13
padresag
why do you need the one that mounts to the exhaust studs? if you have the lower one. you will also need the adj brky that goes from the top of the alt. to the frt of the intake manifold
ron
Old 10-16-2012, 08:28 PM   #14
Rusty one
Rusty one's Avatar
ron
Don't have the lower...borrowed it.seems to be for headers.I already have the long adjustable brkt that goes to the frt of intake.
Old 10-16-2012, 10:07 PM   #15
Rusty one
Rusty one's Avatar
After rereading the above post....I thought I needed the bracket that bolts to the exhaust? Thought that was the main bracket for the alt. As you mentioned it looks like I have the layer exhaust mani..not sure of the year but don't think its from 63.
Old 10-17-2012, 02:39 AM   #16
Rusty one
Rusty one's Avatar
Here are the pics of the exhaust manifold and other pieces I have. Looks like I might need the lower "stock" alt bracket that 1963c10 posted..it's the 4th pic.
Old 10-17-2012, 02:49 AM   #17
padresag
that is the same mounting as I showed to you'
and that goes with the short w/p
ron
