10-17-2012, 03:14 PM | #1 |
Factory Correct Restoration Details
I've searched this forum for a while trying to find little details on factory restoration but I haven't found anything. I know there is a thread for 60-66 trucks but not 67-72.
The question: What are the little details (overspray, finishes, bolt types) that you've found consistent on these old trucks from the factory?? I thought it would be helpful for someone who wants to restore a truck to look factory "correct" if there was a place to compile all of these details and maybe ways that you've found to replicate some of the original details on your truck.
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
10-17-2012, 03:15 PM | #2 |
Re: Factory Correct Restoration Details
I'll start. Idk how accurate this is but if I were to restore an engine compartment to factory I would probably start here
10-17-2012, 04:08 PM | #3 |
Active Member
In a way, but that is a publicity photo its meant just to look good in the sales catalog, the first thing I see wrong is the orange transmission.
But I'm with you 100% on compiling for factory correct restoration, thats the way I'm trying to do my truck |
10-17-2012, 06:07 PM | #4 |
True, I'm pretty sure the transmission is supposed to be silver. But you can see some nice details in the picture on the fuel pump and pulleys. Not 100% accurate but definitely a good start
10-17-2012, 07:07 PM | #5 |
Old member
The exhaust manifolds are for 73 and up trucks. 72 down had ram horns. Nice clean picture though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-17-2012, 08:03 PM | #6 | |
In my teardown I didn't find much in the way of chalk marks on the firewall, I'd be curious to see what anyone has for photos of originals that still carried them. Unless the assembly line process was different enough from the cars that they didn't use them. I'm not aiming for Pebble Beach style correctness, but still trying to make it look stock. So I use shiny bolts where they would have been painted and so on, so don't panic when you see the photo, I'm not claiming its 100%. Still, to me one of the biggest things in keeping the engine looking original are: 1) Correct paint sheens. Most black things underhood are 20% gloss, but the radiator is different (high gloss) and so on 2) Correct clamps and hose fittings and so on 3) Clean everything (check out my clutch fan in the pic below, it was seriously ugly, and that's just a lot of time with a toothbrush) 4) Correct stickers 5) Correct plug wires, correct distributor cap (not HEI), looms, etc. Mine are even Packard wires, though not date coded (I'm not that hardcore) ...and a personal peeve, but one of the most important: 6) If they didn't make or use it in 1970, don't use it. That means no zip ties, as handy as they are. No corrugated plastic wire covers, yellow 10mm plug wires, and so on. Although not always correct, I'm a big fan of "contrast". That means different colors on different parts, different gloss levels, and so on. That's why my shocks are blue below (and because the original GM shocks I've seen were blue) and you'll see about 8 different finishes between the control arm and the spindle. From the factory it'd probably just be all black, but I'm into the variation.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 10-17-2012 at 08:14 PM. |
08-18-2014, 07:53 AM | #7 | |
Here is a b&w photo of big blocks in the rack. You can infer the amount of production representative paint coverage from these, but it also gives an idea of the volume of engines used to maintain production. Incidentally - in one of my previous jobs my responsibility was to review all the brochures, literature and print advertisements for accuracy (so I KNOW some mistakes get out! - lol). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-01-2015 at 07:58 AM. |
10-17-2012, 07:13 PM | #8 |
Don't ever remember the exhaust manifolds being painted - they were bare cast. Also, I believe they should be ram horns for our 67-72's and the wires run down the back of the block and underneath the manifolds. That photo also bothers me in another way. All the old small blocks I have had have the dipstick on the driver's side. Didn't think they started pass side until about 1980? Guess I was a little slow on the manifolds - Andy beat me to it while I was typing.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
10-17-2012, 07:18 PM | #9 |
The point of this thread is to capitalize on the forgotten details that our trucks came with but were forgotten over time. I'll delete that picture if its inaccurate, let's not loose focus here
10-17-2012, 07:33 PM | #10 | |
Old member
The picture just isn't peroid correct for our style truck. So if the person looking for help in his build see's this and assumes it correct they will be very upset when they findout it's not. Just saying...it is a nice color picture though of a small block Chevy engine.
10-17-2012, 08:01 PM | #11 |
SWB 4x4 Collector
Andy, I am seeing a blown up picture of a Big Block chevy. The only small blocks are the multicolor cartoons at the bottom. It's correct as far as exhaust manifolds. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-27-2012, 10:10 AM | #12 | |
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
10-27-2012, 10:45 AM | #13 |
Yes Beetle - later small blocks did but all the 67-72 small blocks I have seen are on the driver's side as are alternators on our SB trucks. I thought they switched dip stick locations in 1979? I completely missed the fact that that picture posted was of a big block when I was commenting on the dipstick, exhaust manifolds etc.
10-27-2012, 12:29 PM | #14 |
Makes me sick to my stomach for painting over all that.
Its in black and not white like everyone elses? At least I have pictures I guess. Posted via Mobile Device
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! |
10-27-2012, 12:31 PM | #15 |
Some factory photos
10-17-2012, 08:01 PM | #16 |
With all due respect Andy, the picture is correct - the engine picturedd is a 402 big block.
JQ
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
10-17-2012, 08:12 PM | #17 |
Old member
Well I stand corrected then if it's a BB. I'm not a BB guy so I can't say for sure.
Graham57a my apoligizes sir.
10-17-2012, 08:45 PM | #18 |
Not a problem, I'm learning just as much if not more then anyone on here. No apology needed, thank you for your input
10-17-2012, 08:59 PM | #19 |
Old member
I sure wished I had, had this board back when I started my truck. Mine isn't a orignal by no means but it would have been nice to had all the info about it captured here.
10-18-2012, 06:41 PM | #20 |
Dave how did you know what colors and finishes to paint everything on your motor and frame?
10-17-2012, 08:41 PM | #21 |
Almost certainly just cast iron, but of course they rust in the first weeks. I used an Eastwood product, and POR-15 and others make similar. Haven't fired it yet, but from those I spoke to it'll stay looking like that for quite a while, and you can touch it up as needed.
I glass-beaded the heck out of them first to remove whatever rust I could, though a chemical dip in rust converter might have worked better. I also blasted a ton of carbon out of the insides, which surprised me. Not that manifolds flow great even when new, but these were really loaded up!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-17-2012, 08:44 PM | #22 | |
07-04-2016, 04:13 PM | #23 | |
10-20-2012, 10:53 AM | #24 | |
10-27-2012, 07:58 AM | #25 |
Ttt . . .
