10-17-2012, 11:03 PM | #1 |
cruising down the road, what pressure do you run in your air bags
air bag pressure, what do you run?
10-17-2012, 11:42 PM | #2 |
Re: cruising down the road, what pressure do you run in your air bags
I'm ready to see some responses! In the middle of a bag swap right now. With a cpp notch, drop spindles, and otherwise stock components on a 66 c10 swb. Thanks
Posted via Mobile Device |
10-18-2012, 12:50 PM | #3 |
I run ~80 up front and ~55-60 in the rear. '62/'63 SWB, 235 straight six, manual trans, Slam RE7's front and rear, '82 front cross member, custom trailing arms out back. I think your responses are going to be all over the map as there are a lot of variables between trucks. Bag size, bag type, bag location, engine/trans size, number of passengers, amount of beer in cooler, etc....
10-18-2012, 03:06 PM | #4 |
needs more $$$
DOMs all around...haven't driven it much, but between 40-50 in the front and 30 or less in the rear. Rides pretty smooth but have yet to be on the freeway.
1970 2wd Blazer |
