Old 10-17-2012, 11:49 PM   #1
69CST4x4SWB
69CST4x4SWB's Avatar
Location: Oregon, The Beautiful Pacific Northwest (GOD'S country)
Won't shift into 4 wheel high!
So my transfer case will not go into 4wheel high! Everything looks okay on the linkage from what I can see and it shifts into 2wheel high, 4wheel low and neutral with no problems. 4wheel high is all the way back, then 2wheel high, neutral and 4wheel low all the way up. This is on my 1969 Chevy K10 and has been this way since I got it 9 months ago. Now that winter is coming I need to get it fixed. Any ideas???
In GOD I Trust All Others I Question!!!
1969 Chevy CST K/10 SWB (Legs)
1969 Chevy C/20 LWB (Old Gray Mare) Donor
1972 GMC 1500 Sierra Grande (Orange Creamsicle) Sold
1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold
1991 Chevy Silverado Ext Cab (LowBoy) Sold
2008 Harley Davidson Electra Glide (Black Betty)
Mark ~ US ARMY VETERAN 2nd ARMORED DIVISION 67th ARMOR
69CST4x4SWB is offline   Reply With Quote
Old 10-21-2012, 04:45 PM   #2
69CST4x4SWB
Angry Re: Won't shift into 4 wheel high!
You mean to tell me that NO ONE else has encountered this problem!?
Old 10-21-2012, 04:54 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
You'd think someone would have encountered that, but I haven't. My K20 has a NP205 t-case and I guess your truck does too, b/c the shift pattern is the same. Maybe someone will jump on here....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-21-2012, 05:00 PM   #4
76k10
Spray the shifter down with WD-40? The shifter on mine gets gummed up every once in a while.
76k10 is offline   Reply With Quote
Old 10-21-2012, 06:57 PM   #5
1969K10
1969K10's Avatar
are the connections just old and sloppy, and you run out of shifter travel before you get in 4 HI?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 10-21-2012, 07:23 PM   #6
69CST4x4SWB
Thumbs up Re: Won't shift into 4 wheel high!
All good thoughts and advice... Thanks! The linkage is not sloppy. I will try spraying down all the linkage with WD40 and see if that helps.
Thanks again guys! And any other thoughts/ideas would be appreciated!!!
Old 10-28-2012, 11:19 AM   #7
72longbed
72longbed's Avatar
You may have already tried this ... but here goes again.
1. Shift your trucks transmission into neutral ... not the transfer case, the transmission. Hold your foot on the brake.
2. Shut off the ignition.
3. Pull transfer case shifter all the way back, do not stop at each range.
4. Let you foot off the brake if it still won't go, and apply pressure back on shifter again. This may give enough movement in the driveline to allow it to engage.
Let us know if this works.
72
72longbed is offline   Reply With Quote
Old 10-28-2012, 11:44 AM   #8
Zane M
How is your fluid level in the tcase? I've seen low fluid cause this problem before.
Zane M is offline   Reply With Quote
Old 12-18-2012, 05:58 PM   #9
fijijason
Did you resolve this? Im having the same issue excpet 4H is in between 2H and neutral. On my 68 K10 on the picture it shows 2H is all the way back and 4Lo is all the way forward. It could be operator error on my part but I cannot find it or 4H is broken somehow. I can get 2H and 4L no problem.
1968 K10 with sb350, 4sp, LWB
fijijason is offline   Reply With Quote
Old 12-18-2012, 06:39 PM   #10
fijijason
Just played with the shifter again and it only feels like there is the three, no 4h found.
Old 06-24-2015, 02:10 AM   #11
benbloom
had the exact problem with having only 3 positions on the transfer case, from forward to back, 2high, N, 2low...anyone have this problem? help!
benbloom is offline   Reply With Quote
Old 08-17-2016, 05:54 PM   #12
69CST4x4SWB
Red face Re: Won't shift into 4 wheel high!
Thanks for all the great suggestions. Even though I first posted this question several years ago and since I rarely drive this rig and even more rare I go 4 wheeling I still have not got back to figuring it out. I have however a renewed interest in fixing it and driving it more often so if you have other suggestions not listed please post them!
Thanks.
Old 12-18-2012, 06:48 PM   #13
Redcap
Take a picture of the back of the transfer case and post it. Need to know what we are working with. I'm pretty experienced with a few different cases.
Redcap is offline   Reply With Quote
Old 12-18-2012, 08:22 PM   #14
fijijason
I looked at pics of the np203 and 205 and this doesnt look like either. I think on top you can make out DANA.
Old 12-18-2012, 09:10 PM   #15
Redcap
I'd say someone swapped in a Dana 20. Not a good transfer case for a heavy fullsize pickup...might want to go trans/transfer case shopping real soon.
Old 12-18-2012, 09:20 PM   #16
fijijason
I guess I should figure out what kind of 4sp transmission I have .......
Old 12-18-2012, 09:26 PM   #17
Redcap
Might be a good idea.
Old 12-18-2012, 08:24 PM   #18
RLONG
RLONG's Avatar
some times the shifter is bumping the hole in the hump i have loosened up the hump cover and moved forward and to see if the shifter was not able to go far enough ahead to engage.
RLONG is offline   Reply With Quote
Old 01-06-2013, 11:40 PM   #19
Yerboogieman
Yerboogieman's Avatar
The only problem I had was shifting it OUT of 4high. I usually have to go real slow and push gently on the shifter and it will just slide out. But sometimes it'll just come out of gear.
-Taylor
1971 Chevy Suburban 4x4 Build Thread
Yerboogieman is offline   Reply With Quote
