Old 10-18-2012, 08:29 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Rebuilding 71 crossmember..
Any tips tricks etc
So far I have collected..
-2.5" Western drop spindles
-Kyb drop shocks (P/N from here)
-Brake pads (summit house brand, is there something better etc??)
-1 stock replacement rotor
-Bearings
It has the factory swaybar 1 1/16" Id like to upgrade to a larger one..
Plans are to disassemble sandblast and put back together with Moog or similaiar front suspension parts. Im going with PS, not looking for dropping alot of $ but dont want to skimp. Looking for a list or something with P/N.
I saw ECE has a package but maybe would it be cheaper to go thru someone else for the same stuff?...
Recommendations for sway bar (Pretty sure my 68 bar came off a 1 ton) Need to upgrade my acct back to blue sometime soon.
Thanks guys any info is appreciated.
John
1999 Toyota Tacoma 4x4
Old 10-18-2012, 08:39 PM   #2
oldblue1968chevy
Re: Rebuilding 71 crossmember..
Also Im cutting the trailign arm crossmember for exhaust cutouts, should I weld a pipe in there for re enforcemtn?
John
Old 10-26-2012, 11:25 AM   #3
LEX
LEX's Avatar
Did you end up welding a reinforcement?
I 'm curious on this as well and am wondering if it is a must to reinforce it after drilling through them.
LEX is offline   Reply With Quote
Old 10-18-2012, 09:13 PM   #4
oldblue1968chevy
also whats the best paint and what options do I have?..
bed liner
spray paint
powdercoat (this is out for $)
tractor paint
rustoleum
por15
summit frame paint
eastwood frame paint
John
Old 10-19-2012, 12:12 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Have you had this sway bar on already or plan to put it on? Almost everyone I know that runs the HD factory bar is pleased with the results. Of course that includes new bushing and usually coincides with a rebuilt front suspension.
That seems to be the most common way to do it. I would use the same method myself.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-19-2012, 12:42 PM   #6
jimmydean
jimmydean's Avatar
I use POR15 for a lot of stuff, so much so I got a dealer account to save money. I also do my own powdercoating because it is cheap to do and durable. Built my own oven, started with the crappy Eastwood HotCoat gun, then upgraded to a pro style gun.
I painted my brake calipers with POR15 just for fun.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-19-2012, 08:01 PM   #7
oldblue1968chevy
The 1 ton bar is on my blue 68 lwb.
My 69 swb has a factory 1/2 ton sway bar. Is it worthwhile to look for a thicker 1 ton or aftermarket bar (of course new bushings too)?
Can I POR 15 bare raw metal? Can I use por 15 on calipers/rotors with the high amounts of heat?
What other things can I do to help handling/performance on a budget (mostly stock front)
Planning on cutting the rivits on the trialing arms and sandblasting insides then welding the seam up and grade 8 bolts in place of rivits
John
Old 10-20-2012, 08:46 AM   #8
cdowns
cdowns's Avatar
if you are using drop spindles with stock springs the drop shocks are not needed are probally wont work properly
Old 10-20-2012, 03:54 PM   #9
oldblue1968chevy
Im planning on cutting the front stock springs or getting a 2" drop spring
Somewhere between 4-5" front drop. I like rake but not sure if I want so much rake that its too much to drive..
John
Old 10-21-2012, 03:43 PM   #10
oldblue1968chevy
http://www.summitracing.com/parts/SUM-D52-728A
These are the pads I ordered...I dont wanna spend a fortune on stuff but dont want to wish that I would've bought different stuff etc
Is there something better? He said Id have to go with a drilled/slotted rotor for a higher quality pad?..
John
Old 10-21-2012, 05:40 PM   #11
eldogg
eldogg's Avatar
I use Raybestos brake and chassis parts exclusively. I think ECE does too. I think it's the best stuff on the market. I would find a 1 ton sway bar for sure. U pull it style junk yards are full of them. Enjoy.
eldogg is offline   Reply With Quote
Old 10-31-2012, 03:34 PM   #12
oldblue1968chevy
What front shocks do I need for 2" drop spring or cut front shocks (thinking about a 3.5" or so front drop combined with spindles)
I have ECE front shocks (dropped) but thinking maybe something else woudl work better?..
John
Old 11-02-2012, 06:41 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd just use the same ECE shocks you have now. They're probably the silver KYB GR-2s. They always ride great for me whether I'm running cut front coils or lowered front coils.
Tx Firefighter is offline   Reply With Quote
Old 11-02-2012, 04:46 PM   #14
oldblue1968chevy
I found the P/N online its supposed to be the same shock ece has for their drop kits
Im all about saving $. Will cutting the coils be the same effect (ride etc) as $100 dropped springs?
thansk
John
Old 11-02-2012, 04:56 PM   #15
outlawz916
cutting coils is just fine, just cut one full round out of the coils and your set.
outlawz916 is offline   Reply With Quote
Old 11-02-2012, 05:13 PM   #16
Tx Firefighter
Agree.
Old 11-14-2012, 10:00 PM   #17
Street Smart
Street Smart's Avatar
thansk
What part numbers did you come up with for the shocks, if you don`t mind.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 11-02-2012, 05:49 PM   #18
oldblue1968chevy
thats what I did on my ol blue truck but going to try to do this one nicer better etc
Still need:
Suspension rebuild stuff (balljoints tie rods etc)
Also, I dont have any (or much) of the steering stuff tierod ends to pitman arm. Should I just order new stuff?
Is there a list with P/N or anything for rebuild components for a 71 72 chevy 2wd 1/2ton?
right now I just have the small swaybar debating going with a larger one if I can find it..
John
Old 11-08-2012, 04:44 AM   #19
2ndstoryslam
2ndstoryslam's Avatar
I scored a complete front-end rebuild kit off the 'bay for a little over $200. http://www.ebay.com/itm/1973-1974-19...item4abe3e0b3f http://www.ebay.com/itm/1971-1972-CH...item564e8b37fb
2ndstoryslam is offline   Reply With Quote
Old 11-08-2012, 10:28 AM   #20
oldblue1968chevy
do you know what brand or usa or china?
John
Old 11-08-2012, 10:35 AM   #21
Tx Firefighter
You'd be hard pressed to buy just the ball joints in an American made source for that money. I recently completely rebuilt a suspension with all top of the line stuff and had way over 500 dollars worth of Moog parts in the job.
I'm kind of a snob when it comes to using top quality parts though. Quality first, price is second priority to me.
Old 11-08-2012, 08:06 PM   #22
oldblue1968chevy
I figured it was china etc
If im going to build it the way I want, Im taking my time and doing it how I want
Thanks for the imput txfirefighter your full of knowledge (good knowlege that is) lol
John
Old 11-14-2012, 10:32 PM   #23
oldblue1968chevy
If you get ece's 4.5/6 drop kit...the shocks are kyb 344068 and 344055. You can get those 1/2 price via amazon or ebay
I got mine thru summitracing, about 25 each
John
Old 11-14-2012, 10:48 PM   #24
Street Smart
kool, thanks.
Old 11-14-2012, 11:19 PM   #25
BMERDOC
BMERDOC's Avatar
Do the Caster Mod!
http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
