Lots of "left over" parts Small and Large all years
1971 12 Bolt Coil Spring Rear end 3.73 open carrier 5x5 bolt pattern
-Sandblasted and painted gloss black with KBS paint $250 plus the ride or u pick up Heavy Rear Bumper – Some light surface rust on back side (non visible) Front is rust free and painted with aluminum colored paint. $100 plus the ride or u pick up Price Drop $80 1971 Disc Brake spindle and discs ( does not have the calipers) $40 plus the ride or u pick up 1967 Drum Spindles with drums, and rear drums. Never been turned down (original thickness), turns freely and no grooves in the metal. $80 (for all 4) plus the ride or u pick upPrice Drop $60 Chrome Rear Sport Bumper -Chrome is starting to flake off on the back side, but is completely straight and dent free Driver quality now but could be rechromed or painted or left as is. $65 plus the ride or u pick upSOLD 1967 L6 250 intake and exhaust manifold with heat sink (crack free and ready to be bolted on) (includes new Fel-pro heatsink gasket if you choose to tear apart)Price Drop $200 L6 Fel Pro Gaskets- All prices plus shipping or u pick upPrice Drop $12 - 250 Head Gasket$10 $5- 292 side cover (2)$4 $5- L6 2pc rear main seal $4 $2.50 L6 water neck$1.50 $2.50 L6 water pump$1.50 Glove Box Door, Hinge, and push button release $30 plus the ride or u pick up$25 HD 4speed Bellhousing $65 plus the ride or u pick up$50 SM465 4 speed Transmission with shifter $150 plus the ride or u pick up $130 1967 Manual steering box with pitman arm, cleaned just needs to be primed and painted $40 Blue Sun visors original equipment, straight, clean, not faded, no indentations, no chipped or faded paint on the rods. $60 plus the ride or u pick up $50 1967 ½ ton (light duty) 2pc coil spring rear long bed truck drive shaft $60 plus the ride or u pick up. $50 Side marker lights Driver quality no cracks both sides $10 plus the ride$8 Reverse light cover Driver quality no cracks Both Sides $6 plus the ride$5 Automatic Shifter handles ( I have 3) $10 ea plus the rideone in the middle pic sold Heater Box plus controls and cables all functional no cracks in good condition $120 plus the ride or u pick it up$100 Deluxe front turn signals/marker lights new in box (2) $7.50 ea plus the ride$12.50 SHIPPEDea or $18 for both shipped Deluxe rear turn signals/marker lights new in box (2) $7.50 ea plus the ride$12.50 SHIPPEDea or $18 for both shipped Headlight Rims off of a 1967, Painted white no rust no dents $30 for the pair plus the ride or u pick up Sold 1967 Front lower splash apron, surface rust only metal is solid and no rust holes, straight not bent. $35 plus the ride$30 11" Kevlar Clutch made by american powertrain. Stage 3 single disc setup 10 spline shaft $350 plus the ride $325 I have many small random parts off of all the years (to many to list) in pails if your looking for something specific I might have it…
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 Last edited by longbed67; 12-07-2012 at 02:07 AM. Reason: Added more parts/Price Drop |
![]() Join Date: Sep 2010
Re: Lots of "left over" parts Small and Large all years
I ll take rear sport bumper pending pics.and price shipped to 35960
![]() Join Date: Jun 2011
I'm needing a good carb off a 67 l6. Rochester model b.
Thanks, Dustin. Posted via Mobile Device |
#4 | |
I am not willing to split the the carb, intake, and exhaust setup apart yet. if you would like the whole setup let me know.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
Thanks. Any brackets?
![]() Join Date: Sep 2011
"Blue Sun visors original equipment, straight, clean, not faded, no indentations, no chipped or faded paint on the rods. $60 plus the ride or u pick up"
Year, pics?
1967 C10 SWB Owner - Rustbelt Restorations |
![]() Join Date: Aug 2008
Put me in line for the sport rear bumper. Is it for a fleet or step?
The bumper shipping to the TX / OK area is $27. It is for a fleetside. here are the photos
I looked a little closer on the paint on the sun visors and there is a few small chips... here are the photos i am not sure which year they came off of they look just like my '67 ones except different color.
Thx but gotta pass, looking for correct late 67, 68 "Blue" visors.
I would like to get more pictures of the center one on both sides.....Thanks Projectjimmie68
Both sides of the middle shifter
![]() Join Date: Mar 2011
Interest in the shifter if u will split pics?
QUOTE=longbed67;5655261]1971 12 Bolt Coil Spring Rear end 3.73 open carrier 5x5 bolt pattern -Sandblasted and painted gloss black with KBS paint $250 plus the ride or u pick up Heavy Rear Bumper – Some light surface rust on back side (non visible) Front is rust free and painted with aluminum colored paint. $100 plus the ride or u pick up 1971 Disc Brake spindle and discs ( does not have the calipers) $40 plus the ride or u pick up 1967 Drum Spindles with drums, and rear drums. Never been turned down (original thickness), turns freely and no grooves in the metal. $80 (for all 4) plus the ride or u pick up Chrome Rear Sport Bumper -Chrome is starting to flake off on the back side, but is completely straight and dent free Driver quality now but could be rechromed or painted or left as is. $65 plus the ride or u pick up 1967 L6 250 intake and exhaust manifold with heat sink and newly rebuilt carb with air cleaner (crack free and ready to be bolted on) $360 shipped or u pick up (includes new Fel-pro heatsink gasket if you choose to tear apart) L6 Fel Pro Gaskets- All prices plus shipping or u pick up $12 - 250 Head Gasket $5- 292 side cover (2) $5- L6 2pc rear main seal $2.50 L6 water neck $2.50 L6 water pump Glove Box Door, Hinge, and push button release $35 plus the ride or u pick up HD 4speed Bellhousing $65 plus the ride or u pick up SM465 4 speed Transmission with shifter $150 plus the ride or u pick up 1967 Manual steering box with pitman arm, cleaned just needs to be primed and painted Blue Sun visors original equipment, straight, clean, not faded, no indentations, no chipped or faded paint on the rods. $60 plus the ride or u pick up 1967 ½ ton (light duty) 2pc coil spring rear long bed truck drive shaft $65 plus the ride or u pick up. Side marker lights Driver quality no cracks both sides $10 plus the ride Reverse light cover Driver quality no cracks Both Sides $7.50 plus the ride Automatic Shifter handles ( I have 3) $10 ea plus the ride Heater Box plus controls and cables all functional no cracks in good condition $120 plus the ride or u pick it up I have many small random parts off of all the years (to many to list) in pails if your looking for something specific I might have it…[/QUOTE] Posted via Mobile Device
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
you got pics of these? 1971 Disc Brake spindle and discs
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
#15 |
They will need to be turned as they have rust on them, but have never been turned previously and are not warped.
#16 |
Is the shifter handles chrome? How much for a chrome one plus shipping to zip 32136? Thanks Pics please...............
#17 | |
There are 3 styles to choose from all chrome let me know which one you want
#18 |
pic
#19 |
The shifter is more or less what makes it cost as much as it does... I only found one place in the states that carries replacement shifters for the sm465 and they wanted $84 plus shipping for a repop one that you had to bend and thread the end yourself to fit your application. I am willing to split it, but I am going to ask $75 plus the ride for it.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 Last edited by longbed67; 10-19-2012 at 03:52 PM. |
#20 |
Thanks for the pics. It is tempting, but I am going to have to pass. I had a lapse of memory on my part, I am going to stick with my 6 lug for now(got a nice set of wheels already). Good luck, should be a quick sale.
#21 |
Interested in the 69 gear shift lever. Does the lever handle unscrew so it can be replaced? Please put me next in line for the 69 shift lever.
Thanks, Rich |
#22 |
Not sure, but I believe the bottom lever is a tilt wheel lever.
#23 |
Looking for a 6 lug 16" x 6.5" Steel Wheel?
"The Can't Family Lives Across The Street" |
#24 | ||
I only have a set of 15" 5x5's rims with almost new tires (1 year old and 2500 miles) on that I have been rolling the truck around on, I would let go for $400 wheels and tires plus the ride
#25 |
interested in the metal headlight bezels pending pics. and shipping to 24556. you dont happen to have the grill loops? one or both? thanks
Ryan |
