Old 10-19-2012, 11:57 AM   #1
76k10
Truck keeps eating brake shoes
The rear drums on my truck go through shoes like there's no tomorrow. Like in a few hundred miles. Truck hasn't been through deep mud either. What is going on? Or just I just throw in the towel and let the rear brakes go.
76k10 is offline   Reply With Quote
Old 10-19-2012, 12:55 PM   #2
UPNADM
UPNADM's Avatar
Re: Truck keeps eating brake shoes
What brand?
New springs and hardware?
E Brake Cables adjusted properly?
Adjusters working properly?
UPNADM is offline   Reply With Quote
Old 10-19-2012, 03:17 PM   #3
76k10
Originally Posted by UPNADM View Post
What brand?
Oreillys shoes. New hardware and wheel cylinder installed on 2nd to last set of shoes. New adjusters that seem to be working. Ebrake not hooked up.
Old 10-19-2012, 03:23 PM   #4
bnoon
Are the fronts working at all? That's about the only way I could see both rear wearing out quickly and at the same time.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 10-19-2012, 03:26 PM   #5
76k10
Front discs work great
Old 10-19-2012, 06:46 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
A bad rubber line holding some residual pressure making them drag?
Old 10-19-2012, 07:15 PM   #7
76k10
That may have some merit. Have y'all heard of anyone else having this issue even occasional mud and water? I haven't sunk this truck in mud but it has seen mud.
Old 10-19-2012, 11:21 PM   #8
gramps77
Ive seen it as well. Swelled so bad it wouldnt even allow pressure to pass. Only found it trying to bleed brakes. Im assuming you have the original rubber hose. Id think it suspect.
gramps77 is offline   Reply With Quote
Old 10-20-2012, 03:08 AM   #9
76k10
Do those hoses usually show visual signs of swelling?
Old 10-19-2012, 09:01 PM   #10
asphaltburner
asphaltburner's Avatar
I have a '72 VW SuperBeetle that had internal brake-fluid swelling of the rear rubber lines due to age. Caused the lines to retain pressure and keep the rear brakes slightly engaged even after the pedal was released. Only vehicle, of many, that I've ever seen this problem on though,...perhaps yours' has the same.
You can check for heat in the drums after a fairly long drive with the back of your hand.
Hope this helps!
Good luck, man!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 10-20-2012, 03:10 AM   #11
asphaltburner
No, not on the outside.
Just replace them,...they're relatively cheap.
Todd.
Old 10-20-2012, 07:41 AM   #12
liftlawssuck
liftlawssuck's Avatar
^^agreed^^^. Seen it as well.
liftlawssuck is offline   Reply With Quote
Old 10-20-2012, 09:57 AM   #13
76k10
I am going to pump the brakes and crack a rear bleeder to see if it holds pressure.
Old 10-21-2012, 12:05 AM   #14
gramps77
Todd.
yeah, what he said.
there was NO external signs of swelling. Then we cut it in half and it had swelled shut to not being able to pass ANY fluid.
Old 10-20-2012, 06:56 PM   #15
donut
donut's Avatar
While the swelled brake hose has merit, in fact if in doubt change them. Question, how are the drums?
I had front drums on an old Impala that would eat shoes every 6 mos, until the drums were replaced.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-20-2012, 07:20 PM   #16
76k10
Replaced the drums two sets of shoes ago.
Old 10-20-2012, 10:36 PM   #17
wilkin250r
wilkin250r's Avatar
Just to lend yet even more credibility to the brake line theory. I've personally never seen it with the rear brakes, but I have seen it with the fronts a few times.
The other possible issue is the brake fluid itself. I imagine you've bled the brakes, but have you REALLY bled the brakes? Enough that you've flushed all the old fluid out and replaced it with new fluid? The brake fluid will absorb moisture over time and lower the boiling point. It can get to the point that any heat in the system will cause the fluid to expand, which creates more pressure, which creates more friction, which creates more heat and thus creates even more pressure, friction, heat, ect. You can bleed the initial pressure off, but the cycle will repeat until you remove the moisure by completely flushing the brake system of all the old fluid.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
