Old 10-20-2012, 12:25 PM   #1
74baggedbug
Fuel gauge!!!
What could be causing my fuel gauge to read like this , it's a new cluster and brand new circuit board .. Thanks for any help/tips
74baggedbug is offline   Reply With Quote
Old 10-20-2012, 12:27 PM   #2
FTP
FTP's Avatar
Re: Fuel gauge!!!
bad sending unit
FTP is offline   Reply With Quote
Old 10-20-2012, 12:27 PM   #3
FTP
FTP's Avatar
Re: Fuel gauge!!!
or, lost ground?
Old 10-20-2012, 12:46 PM   #4
74baggedbug
Re: Fuel gauge!!!
Well I have a fuel cell under the bed , I will start there and check the ground 1st and if that doesn't work then ill order a new sending unit . Thanks
Old 10-20-2012, 02:00 PM   #5
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
Re: Fuel gauge!!!
I was about to post about my fuel gauge not working , my cluster and sending unit are new . Where would the ground wire be ?
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 10-20-2012, 02:21 PM   #6
GMCJOE
GMCJOE's Avatar
Re: Fuel gauge!!!
The tank itself is the the ground. You can always check to see if it is a grounding problem by taking a piece of wire putting it anywhere on the sending unit that is metal and grounding it to a known good ground. If it works right, you know you have a grounding issue.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-20-2012, 02:40 PM   #7
Littletony
Littletony's Avatar
Re: Fuel gauge!!!
If this does not make it read full then you have a power issue.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 10-20-2012, 02:16 PM   #8
GMCJOE
GMCJOE's Avatar
Re: Fuel gauge!!!
What gauge setup did you have in your truck previously? Idiot cluster or Gauge Cluster?
Joseph
Joe's 69 GMC
Old 10-20-2012, 06:22 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Fuel gauge!!!
This is an indication that the sending unit wire to the gauge is grounded to the frame and not grounding through the resistor in the sending unit. Pull the sending unit wire off the unit at the tank and with the key on you should get a gauge reading at 3:00 o'clock.
If it still reads where it's at, then pull the sending unit wire off at the fuse panel and re-check the fuel gauge. if it then goes to the 3;00 o'clock then the sending unit wire is grounded between the fuse panel and the sending unit. Possibly pinched and grounded somewhere.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-05-2012, 08:13 PM   #10
74baggedbug
Re: Fuel gauge!!!
What sending unit can I use for the fuel cell? I'm gonna try and fix it this weekend coming up and just trying to get all the parts ready
Old 11-05-2012, 09:04 PM   #11
GMCJOE
GMCJOE's Avatar
Re: Fuel gauge!!!
http://www.egauges.com/vdo_indS.asp?...90ohms&PN=SN38
This is just an example, one that I am thinking of using on my 40 gallon cell. They have others listed that you can choose from, or just an idea of what you can use.
It has to be a 90 ohm sending unit.
Joseph
Joe's 69 GMC
Old 11-05-2012, 10:31 PM   #12
Square_78
Square_78's Avatar
Re: Fuel gauge!!!
Did you just do the white face gauges on it? Needle may have been installed in the wrong position. When i did mine i was careful to reinstall the needle in the same position as it was before i took it apart.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-05-2012, 11:25 PM   #13
74baggedbug
Re: Fuel gauge!!!
I thought the same thing but I rotated the needle after the 1st time and it went back to the same exact spot
Old 11-05-2012, 11:32 PM   #14
Square_78
Square_78's Avatar
Re: Fuel gauge!!!
Did you pull the needle off and reposition it? Fill up the truck with gas at the gas station, pull the custer out, pull off the needle, and then carefully push the needle back on so its lined up with the "FULL" marker. Try NOT to rotate the needle at all while doing this. Get it so that its resting and lined up with "full". Its kinda tricky to get those needles back on and lined up properly.
#teamlongbed
