10-21-2012, 09:19 AM | #1 |
Robert Olson Transport
new one for the herd.. a CUCV story
one of the things I do for a living is to buy and flip houses and I have several that I rent out here in NJ. Last year i took my beater truck and restored it which caused me to lose the truck that I was using for all the dirty work. I had my daily driver 2011 F 150 but being its almost new I dont like to terrorize that too much, besides with all that new technology its screwey anyway
Ive always wanted a CUCV so on a lark i went on government liquidation and found a local one and low and behold i won it. Hopefully this week I can get it out of the base and get it back here and figure out how to get it running . The plans are get it running , fix the hood ,throw a tool box and ladder rack on it, and maybe a tilt setup for the bed , a snow plow and a winch and call it a work horse beater This should work also to pull deer out of the woods too heres a pic as I won it... you guys have seen as much of it as i have more to follow as we go here
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-21-2012, 09:44 AM | #2 |
I know the pieces fit
Re: new one for the herd
Congrats! Stout as hell truck. Mine was advertised as not running but fired up and drove on the trailer - hope yours does the same. I think they advertise them that way in case the batteries have died or have driveshaft damage from being moved with a fork lift. Subscribed.
10-21-2012, 12:27 PM | #3 |
Moderator
Mine had no tie-down shackles, no key, and no batteries. The short battery to battery cable was missing as well. I showed up prepared with a CUCV key, driveshaft, batteries, battery cables, and a tow bar that hooked into the D-Ring points. It started up so we didn't have to push it out of the tight spot they parked it in to hook up. Looks like yours is a little easier to get at. I've heard that not all DRMO depots allow you to do anything other than hook it up to the tow-bar or drive/winch it on the trailer.
All of the CUCV Technical Maintenance (TM) docs are available in PDF format on the Steel Soldiers forum so there's no need to pay someone on eBay for them. The electrical is a good NATO compliant hybrid 12v/24v that works well. Jumping from another MV when yours' has dead batteries cranks it right up. Just fix any issues it has and go. 6TL batteries aren't necessary or even desirable but anything else needs some re-work to fit. Don't just set them in there and drive it around. I used Optima Red-tops with custom fabbed tie downs. Look up "Doghead mod" on Steel Soldiers to fix the flaky GM starter relay. I waited several months and then did it after I burned up my original starter from the flaky GM unit. I use a Delco 24v 28MT and the 6.5L 28MT tail bracket now. Don't run either the 27MT or 28MT without the right tail to block bracket. Don't buy the chintzy Chinese starters they don't hold up. I bought mine from a local re-builder re-worked with GM AC Delco parts and kept the heavy 27MT just in case. Change the door and ignition locks immediately otherwise anyone could steal your new rig without even hotwiring it. My M1008 had a bunch of intermittent electrical issues. Disassembling and cleaning the grounds with a brass brush was all it took to make most of the gremlins go away. I added a shot of Wurth HHS after I finished cleaning them but any electrical corrosion inhibitor like Fluid Film is good.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-21-2012 at 12:50 PM. |
10-21-2012, 12:54 PM | #4 |
Cool truck, I look forward to seeing more of it.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
10-23-2012, 09:13 AM | #5 |
first update is ive been able to locate a guy who can go to the base and get the dern thing home for me, thanks to one of the CUCV gurus here, Gerry, I met a professional tow guy who has alot of experience with getting things out of the base. Apparently mine was satationed in Picatinny Arsenal, Dover NJ.Hopefully tomorrow ill have some pics of the thing and a good idea as to what its going to take to get her running
10-23-2012, 09:41 AM | #6 |
Next!
On a positive note, Bob, one of the few CUCVs that I ever bought from GL that ran on its own power was from Picatinny Arsenal. Ritch will bring it back safely to you.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
10-23-2012, 10:33 PM | #7 |
Off Road Richie got the truck to me today in the afternoon. His driver Eddie was nice enough to lend me his CUCY key and i had a few duplicates made. First order of business was to inspect the truck and it is apparent there are little to no brakes caused by a rotted rear brake line. In addition the batteries were deader than a doornail . I did attempt to charge them but one seemed pretty bad the other seemed like it would take a charge but it wasnt going to be easy as some cells were low, so after about three hours on the charger i broke down and bought a couple of batteries from AutoZone and threw them in. Apparently CUCVs have a priming thing so a few squeezes and a shot of ether into the air cleaner and suddenly the far side of the street disappeared in a thick cloud of black acrid smoke.. She fired up and idled after burning off a whole bunch of black stuff.
We also found out someone left the black lights on and that may have killed the batteries. Other problems with this truck include a small leak outta the rear diff, the right side wheel needs ball joints and the left front hub is a little sloppy.t needs the tailgate fixed and the door seals are shot Once we got it going and left it idle a half hour we tried moving it and it went forward and backward and made it into my driveway under its own power . I applied for the paperwork to register the truck and hopefully in a day or so Ill have plates on it and we will see how far it goes
10-23-2012, 10:34 PM | #8 |
one ladt pic.. tomorrow we start fixing little things on the truck to get it more road worthy
10-24-2012, 05:38 AM | #9 |
Next!
The adventure has begun . . .
10-24-2012, 07:11 AM | #10 |
She's a beauty. Congrats -
I don't remember both batteries being on the RH side.... The reason I say that is...well, because we built these trucks during my tenure on the line. The person that installed the battery in my area was a somewhat diminutive African American lady. She did ok installing the regular batteries but, because the CUCV trucks were so high up and because the batteries were a tad bigger - she simply couldn't reach. She tried for a little while and then eventually gave up. So - guess who installed the battery on every CUCV truck that went by (every 12th build)? Me. Now that I think about it I have no idea why we didn't just move her to a different job.... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-24-2012, 01:52 PM | #11 | |
Windy Corner of a Dirty Street
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
10-24-2012, 02:10 PM | #12 | |
Next!
BTW anything you would ever want to know about CUCVs is over on www.steelsoldiers.com
10-24-2012, 02:46 PM | #13 | ||
I was the air induction engineer at the time and was able to convince the Chief Engineer I needed that spot in order to meet his flow (and therefore HP) requirements. We had a little meeting with the battery guy and I had better data. K
10-24-2012, 08:39 AM | #14 |
the deka CUCV batteries that came out of those well lets just say im glad they have rope handles on em to make em easier to swing otherwise there would have been a number of expletives in lifting them lol
10-24-2012, 10:22 AM | #15 |
Re: new one for the herd.. a CUCV story
Do NOT ether it again! That is a major cause of failure if your glow plugs are working! BTW it probably wuill not start with bad glows. One of the best mods I ever made was Delco 60G's, Ferd starter relay, and override switch. But ether and 6.2/6.5's don't mix. If you must use a starting fluid use WD-40. But fix the glows and you should have no problems. I actually started my 6.2 after leaving the headlights on for 6 hours. And I've had it start on the 2nd crank after sitting 6 months. Good glow system is the key.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
10-24-2012, 10:53 AM | #16 |
if for some reason you doont want the brush gard and bumpers i will take them off your hands its looks in good shape should give years off work for you. also with the glow plugs put them on a toggel switch that way if need be you can use wd40 with no problem and with mine i dont need the gp all the time just after sitting for a few hours do i
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
10-24-2012, 12:27 PM | #17 | |
The dieselplace and steelsoldiers are good sources. The doghead mod is as easy as it looks and works as advertised.
10-24-2012, 11:46 AM | #18 |
Nice score on CUCV, stop by dieselplace and you will find a lot of good info.
Steel soldiers is good for info too. Ditto on not using ether, very bad.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
10-24-2012, 12:11 PM | #19 | |
Moderator
CUCV glow plugs aren't the same as the civvy units. Steel Soldiers has an article on the glow plug system sitckied in the CUCV section.
And please let us know if and how your repairs were successful. |
10-24-2012, 01:07 PM | #20 |
Im keeping the brush guard lol the guys who work for me need every bit of help they can get to not bang it up. Today i had one of my guys remove all the racks and clean out the bed. Its surprisingly clean in there no real rust. I had the old tailgate we had from the restore on the other truck so i swapped them out.. six bcks for a can of camo paint and it looks decent on there.
We replaced the brake line and she had decent breaks. Im going to replace the inner fender wells and the passenger fender as theres some rot on that but thats only to support the new batteries Alot more cleaning and it wont be a bad work horse..
10-24-2012, 05:39 PM | #21 |
Nice score.
And your street is crowded. Nobody have a driveway there? =-) Alex. |
10-24-2012, 07:10 PM | #22 |
lol I just did the concrete in my driveway so i cant put all my wrecks in the yard.. the neighbors are getting peeved lol
10-26-2012, 09:10 AM | #23 |
thanks to the other thread on glow plugs and Gerry GM72K10 i found some good information. I ordered a card from CUCV electric which is less expensive than others i had found, and after searching around I met a guy who says hes a member here, John "Hillbilly Wizard" who specializes in all kinds of 4X4s and parts out Military trucks. Hes right down the road in Toms River NJ so last night I went shopping. I scored 8 glow plugs NOS, a good hood ( mine is dented and rusty) the right fender ( not from a CUCV but a yellow Navy suburban) a front seat, a relay for glow plugs, a good spare on a rim, and a box of extra bolts for $200 plus me and my helper scored his company tee shirts for free lol Im told he is a member here so a kudos and thanks to ya I will post pics later
10-26-2012, 10:17 AM | #24 |
^^^^ Nice, Hillbilly is cool, wish I was closer he had a set of mirrors I was looking for.
10-26-2012, 07:43 PM | #25 |
Next!
"Hillbilly" is a nice guy, met him at the Gilbert mv show in September.
