Old 10-22-2012, 09:10 AM   #1
jus2qwk
jus2qwk's Avatar
will 37s fit on a 4 inch lift?
well the plan is if I buy this blazer it to do a 4 inch lift and try to use 37s. i dont wanna have to cut anything bit if I have to I would cut the front fenders but I wony cut the back. will they work?
lift= http://www.roughcountry.com/chevy_69-72_4.html
tires= http://www.militaryoffroadtires.net/...t-37125165.htm
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 10-22-2012, 10:13 AM   #2
jus2qwk
jus2qwk's Avatar
Re: will 37s fit on a 4 inch lift?
with these beig used tires I guess they would really be like 36.5s.
I have another question with a 4 inch lift do I have to do anything with the driveshaft or will the stock one work?
Corey Jones Designs
Old 10-22-2012, 10:20 AM   #3
fun in dirt
fun in dirt's Avatar
Nope, needs to be 6" lift at least. I've got 5" lift, with some fender trimming & 36s & they occassionally rub. But good thing about the military 37s is they don't have big lugs sticking out the sidewall that can catch a fender as easily when turning.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-22-2012, 11:22 AM   #4
Burt4x4
Burt4x4's Avatar
I could get 33"ers too rub while offroad twisten down the path on a 4"lift & 3"body so...gotta cut or go up...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-22-2012, 11:26 AM   #5
Firebirdjones
I run 33's with no lift and it's fine on and off road. I've never once experienced a rub even when articulated. 37's really don't sound that much bigger. Only 2" height difference at the tire when you figure the circumference. So in theory a 4" lift would be more than enough in my case if I wanted 37's. Albiet that doesn't take into account a really wide tire, which will make a difference.
Firebirdjones is offline   Reply With Quote
Old 10-22-2012, 11:46 AM   #6
jc06vmax
jc06vmax's Avatar
Originally Posted by jus2qwk View Post
I also run 33 12.50s at stock height. I haven't been through anything real gnarley off-road but at factory height they haven't rubbed any. The only scrubbing i get is when i turn the wheel all the way in, and even then it just barely rubs. I feel like a 4" lift should be plenty to clear the tires. The only thing I would be a little concerned about would be a little scrubbing with the wheel turned all the way, but since those are 12.50s too I would assume it would be the same difference as what i have. I'd say go for it!
jc06vmax is offline   Reply With Quote
Old 10-22-2012, 11:50 AM   #7
Burt4x4
Burt4x4's Avatar
Stock springs behave alot differnt than aftermarket.
I gurentee if you try to follow me you will rub
Old 10-22-2012, 11:58 AM   #8
Burt4x4
Burt4x4's Avatar
I suppose if you stay on pavemnt for the most part you won't rub but it will be close...
The front of your rear wheel well and the back of your front wheel well will be the spots to watch out for...
Good Luck and post pics
Old 10-22-2012, 12:46 PM   #9
jus2qwk
jus2qwk's Avatar
Like I said before I would cut the front if its an issue because new fender are so cheap but the rear I really would wanna keep factory.. just incase I decide to sell it later on down the road. and looking at some of the trails you go down I dont think I will be doing anything that crazy. just some fire roads with some mud holes
Corey Jones Designs
Old 10-23-2012, 11:52 PM   #10
craigger007
craigger007's Avatar
You will rub on turns. I have 37s with a 6 inch lift and it rubs.
craigger007 is offline   Reply With Quote
