10-22-2012, 09:59 AM | #1 |
Fuel gauge question? 1985 Chevy C30
In our repair shop we checked out an 85 C30 that the fuel gauge would read different everytime the truck was turned on. Tested and found the fuel gauge was testing bad. Removed and replace the fuel gauge with a new gauge. Now the gauge reads the same everytime the truck is started but moves around while driving. It acts like it is just reacting to the sloshing of the fuel-- starting, stopping, cornering, if you park on an incline. Should the gauge have a slosh module to help with this? Could it be a problem in the new gauge? I was hoping someone has been through this already and knows the answer to the problem. Thanks for your time and knowledge.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
10-22-2012, 10:10 AM | #2 |
Re: Fuel gauge question? 1985 Chevy C30
others may disagree but the squarebodies ive had in the past were the same, truck needs to be on level surface to read the gas right.. may have more to do with the sending unit design then the gauge.
just my 2 cents |
10-22-2012, 06:45 PM | #3 | |
I can be cruising at 1/2 tank and come to a stop sign, she jumps to E and then back up to 1/2 |
10-22-2012, 07:10 PM | #4 | |
10-23-2012, 03:10 PM | #5 |
In my experience, it is a sending unit issue. Aftermarket sending uints like Spectra brand, will move around whenever the vehicle is in motion, or stops quickly. Others will disagree. Delco sending uints are about $14+, Spectras are about $40 - I have bouncing Spectra sending units in my truck.
10-23-2012, 04:34 PM | #6 |
78K & 79C Jimmys
i just replaced the tank and sender in my 79
both Spectra brand (no bouncing issues before or after) i had a bouncer in the 78 tho Spectra brand again but changed the cluster from idiot to tach/gauge added some grounds behind it and the bounce went away when i first looked into the bounce ,adding a ground was suggested here not sure why it didn't help me when i test grounded it and why it stopped when i added the diff cluster i can only suggest there must be feed back disrupting the path to ground seeing they all go to one wire and it can't hurt to add one... when I ordered this one my parts guy said he never heard of this issue and he sells a lot of the Spectra brand and tank is not baffled
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
