Identifying rally wheels
Is there a way to tell the difference between the pre-72 6 lug rally wheels that won't work with drop spindles and the 73+ 6 lug rally wheels that will work with drop spindles (other than test fitting of course
Re: Identifying rally wheels
There are no pre 72 ralley wheels. I believe the first year for ralley wheels on the trucks was 1975.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
67-72 parts collector,…
![]() Join Date: Nov 2002
x2.
I understand. I thought I had read something that said rally wheels wouldn't work, but maybe it just meant that factory 67-72 wheels wouldn't work. Below are the wheels I have now, I don't think they are factory because when I bought the truck the guy told me he had just replaced the wheels and tires. Will these wheels work with drop spindles and no mods to the control arms?
You will need to mod the control arm slightly.
I have these on my truck. 67-70 drum brake steel wheels will not work with disc brakes. You would need 71-87 steel wheels or any of the rally wheels.
#6 | |
Posted via Mobile Device |
You have 6-lug rally wheels.
They come in 15x8 and the rare 15x7 size. Most stock steel wheels are 15x6.5 and take a hubcab
Thanks for all the help I guess I need to read some more
![]() Posted via Mobile Device |
I am a Referee of life.
Rallies on my 68,like those pictured.They have worked fine and I haven't modded the control arms.I've heard both ways so you may have to do a little grinding to allow full turns.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Don't sweat the a-arm trim.
I've been doing it for 25+ years. Posted via Mobile Device
Just trim the minimum to make the wheel spin and turn lock to lock at ride height.
Curious if the 15x7 version of my wheels still require a arm trimming. I like them just for the tuck factor.
#14 | |
The 15x7 6-lug rally wheels have 4" BS. The 15x8 6-lug rally wheels have a 3-5/8" BS.
#15 |
Is a 255/70 going to be too big for the 7" rim on the front with a 4" drop?
#16 |
![]() Join Date: Mar 2012
You might want to go with something more like a 225/70 in the front and a 255/70 in the rear. The trimming you need to do to the a-arms is very minor and not structural. It wont result in failure if you take off the small amount you need to stop the rubbing. Take your time and grind a little off and try again, then grind off a little more. Its easy to do.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#17 |
helpfull info here. thanks!!
