Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-24-2012, 05:20 PM   #1
davepl
davepl's Avatar
Welding on a painted floor - ideas?
I'm doing subframe connectors on my Camaro, and it will entail a lot of welding under the car (mostly MIG). Unfortunately I just had my shop floor coated (that speckle finish) last fall, and it's not burn proof.
I'm wondering what I can put down on the floor that will protect it. I was thinking perhaps a sheet of plywood that soak with a hose first, but slag will likely still ignite it. Perhaps drywall (gyprock), but that has a paper coating.
Obviously a big sheet of steel or a pile of sand would work, but those aren't really practical, so I'm looking for any good suggestions!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-24-2012, 05:52 PM   #2
SS Tim
SS Tim's Avatar
Re: Welding on a painted floor - ideas?
I'd think just a couple of sheets of OSB or plywood would be fine. Just keep a mop and a bucket of water handy. Then just hit it as it dries or starts to smolder too much. Or maybe some of the tile backerboard over a tarp.
But if you really want to get fancy build a couple of 4x8" 2x4 framed sheets of plywood on casters with a layer of sand. A portable sandbox/sandtable for your toys.
SS Tim is offline   Reply With Quote
Old 10-24-2012, 06:15 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
3M Welding paper ? Superflysteiney used it when welding up a custom raised bed floor in a freshly painted truck in his "tootsie..." build.
http://3mcollision.com/3m-welding-an...per-05916.html
Edit: just read the description: not designed for horizontal surfaces, Doh
How about a welding blanket?
http://www.toolking.com/lenco-08820-...FQhyQgodYkwA2w
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-24-2012, 06:35 PM   #4
Fitz
Yes, it really does exist...3M Welding Paper!
Works Great, too!
Fitz is offline   Reply With Quote
Old 10-24-2012, 08:29 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would get a welding blanket or two.I have heard but never tested that you could soak a wool Army Blanket in a strong borax solution then airdry it and it would fireproof it.You might want to put a sheet of plywood down with a welding blanket over it to prevent heat transfer.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-24-2012, 08:46 PM   #6
KyFarm
KyFarm's Avatar
a welding blanket is what you need
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 10-24-2012, 10:36 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
You could also go to the home center and get a few sheets of ceramic tile backer board (I always called it cement board) That would work.
LockDoc
Leon
Old 10-25-2012, 11:44 AM   #8
BHyatt
I always look for the simplest solution myself. Weld it in the driveway.
BHyatt is offline   Reply With Quote
Old 10-25-2012, 01:15 PM   #9
mrein3
mrein3's Avatar
While I agree with the idea of trying the simple solution first (my best friend always says don't over think it), keep in mind that you can't use the mig process outside. When you are outside you need to use flux core which brings with it other issues.
I've been watching this thread myself because I just painted my new floor in my new shop and don't want a bunch of burn marks on it either. I'll be ordering myself a welding blanket when I "move in" to my new shop.
Another problem with "in the driveway" where I live is that pretty soon it will be below zero out there. Its pretty tough to control your weld puddle when you're shivering.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-25-2012, 01:19 PM   #10
budman k20
1972 K20
I keep a 3 x 6 sheet of sheetmetal in a corner and whenever I do any cutting with a torch I place it under the work area. Your creeper or whatever rolls right over it.
budman k20 is offline   Reply With Quote
Old 10-26-2012, 06:58 AM   #11
hugger6933
The 3M weld paper is great but it is like $ 100 bucks a roll. I have a fibreglass welding blanket that I put up when I am welding on rocker panels and door opening and such [doing one today in fact] I also have some tile backer board from the bathroom remodel here at this house and our rental hosue down the street[it is concrete or something like it] Try to have a fire ex. handy I know it is a know brainer but I almost lost my whole shop a couple years ago cause akid working for me cut a floorwith a plasma and hit a fuel line and did not have one near by. He freaked started runing and the fire was sucking the gas from the tank and kept feeding the fire! Just please stay safe most of all and have fun, and you problem may be as simple as a wet down with a water hose? Jim
hugger6933 is offline   Reply With Quote
