10-24-2012, 10:22 PM | #1 |
Still having issues with my gas gauge
Well most of yall now by now about my gas gauge lol
i just cant get it to work I installed a new tank and a sender cleaned the ground for the sender real real good the green wire on the sender cleaned it with some connector cleaner but still can get a reading I have 3 different gauges One is the factory or i think the factory gauge of the truck One is off a 83-87 small jimmy or blazer not the big one the little ones the last one i got from a member here with a few other gauges Okay well the factory gauge stays at the 1/8th of a tank the one off the jimmy starts at e then goes up slowly to the 3 o clock position the one i got from a member goes straight to the 3 o clock position the sender is grounded, and everything is seated idk what to do anymore could i just run the wires straight from the sender and 12v and ground to gauges? Thanks for any help frog
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
10-25-2012, 06:24 AM | #2 |
Re: Still having issues with my gas gauge
I have done all the same things as you and im still stuck at 3 oclock, i even added a ground lol. Didnt help. Hopefully theres another solution
Posted via Mobile Device |
10-25-2012, 09:25 AM | #3 |
78K & 79C Jimmys
i'd check the sender wire,maybe run a temp/tester wire sure
it will go like that if the sender wire is off if it's working right and you ground the sender wire it will go to E my jimmy has an "extention " wire (looks stock)from halfway down the frame
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-25-2012, 09:49 AM | #4 |
Moderator
3:00 means the sender signal isn't reaching the gauge.
You state the ground from tank/sender to frame is good. I am assuming this is your 1974?? You didn't state the year in your post. The sender wire is Green??? Maybe Light Blue? Originally it had 73-80 Dual tanks? The 73-80 single tank systems usually used Tan for the sender. On the 73-80 dual tank systems a DPDT dash switch selects which sender is in use. If the truck has been "converted" to a single tank the wiring is probably still there. Is the dash switch good? or unplugged?? or missing with the plug dangling??? or plug is cut off and wires left dangling???? Have you checked the sender to tank switch wire for damage? Is the tank switch working? Is the Tan wire that runs from the tank switch center terminal, through the tank switch wiring grommet, into the firewall bulkhead connector OK? Have you checked the wire that runs inside the cab from the bulkhead plug to the instrument cluster plug for damage? Are the 3 cluster clips making firm contact with the studs on the gauge? I just posted my scans of the 1974 GM wiring diagrams.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
10-25-2012, 10:41 AM | #5 |
mines stuck at 3/4 of a tank...and when you pull off a gauge from another truck, are they supposed to be able to move ( the needle) and stay where u move it, or are they supposed to be like the speedometer and after turning or moving, go back to E mark?
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe Last edited by slam59; 10-25-2012 at 10:53 AM. |
10-25-2012, 11:01 AM | #6 |
On my 1976 pass side single tank, the sending uint wire is one solid tan wire from pin 13 of the firewall bulkhead all the way to tank sending unit. This wire is part of the engine wire harness and travels behind engine, then down with starter wires and then over to frame rail.
It could be possible you have a break/short in that wire somewhere. I would disconnect engine harness at firewall and check continuity (ohm) of the wire from sending unit to pin 13. If its bad you could easily run a new wire from tank to the firewall bulkhead. Checking it this way you would know if the problem is external of the truck or internal (dash, harness etc). I would also check continuity of your sending unit connection to ground (frame), thats very easy to do.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-25-2012, 11:51 AM | #7 |
78K & 79C Jimmys
stay
10-25-2012, 06:37 PM | #8 |
Sorry ya mi truck is a 74 I have not checked the tank switch its been running on the left tank only its a dual tank
My sender wire and ground are connected mi sender wire is green and black for ground I will have to check the wire connector at the plug I also added a mother ground behind the dash but no help Posted via Mobile Device
10-26-2012, 12:54 PM | #9 |
Moderator
Probably the dash switch. If it's there, working, and hooked up, switching to AUX should complete the RH tank gauge circuit.
10-31-2012, 05:49 PM | #10 |
well guys
i think i made some progress found a tan, brown wire running from the valve selector? up the frame almost to the cross member but was cut i then found this wire with i guess you can say alternator wire bundle that was cut too they looked the same so i connected them and well this is what happens now when i switch to the left from the switch it goes to the 8 o clock position then when i switch to the right tank it goes to the E i use the left tank, i dont use the right tank
10-31-2012, 07:20 PM | #11 |
Sounds to me like you need to test your resistance in your sender wire leading to your gas gauge. Test at the wire that plugs right into the back of the gauge. Follow the lines on your printed circuit on the back of your gauge cluster all the way to the wire that the plug itself plugs into. That will of course be the fuel sender wire. A factory GM fuel sender from these years of trucks will operate on a 0-90 Ohm resistance reading. Or was it milli-ohms? Or the other one? Someone help me out here. Can't remember but its some degree of resistance measured in Ohms and the operational numbers are between 0 and 90. 0 indicates an empty tank, and 90 indicates a full tank.
So what would your Ohmmeter (or just a voltage meter with an ohms setting) read if you had half a tank? That's right, 45 ohms. Or right there in that area somewhere depending on exactly how much fuel you had in the tank of course. So what you need to do is take your meter and test your wires for the proper resistance. Once you find that the wire is in fact reading the right ohms for roughly how much you have in that tank, then you've just confirmed that your wire isn't grounding out somewhere and your gauge is getting a good signal from the sender. Now time for my personal opinion. It ain't pretty lol. All those stock gauges belong in a garbage can. Get you a good aftermarket gauge (I used autometer) as they actually work to filter out some of the stuff you don't want like the wavy needle, and they are more accurate as well. |
10-31-2012, 07:36 PM | #12 | |
Will have to try with my multimeter tomorrow thanks
10-31-2012, 07:53 PM | #13 |
told you in above reply the wire was tan lol
Im glad your making progress.....you will get it eventually
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 10-31-2012 at 07:59 PM. |
10-31-2012, 09:02 PM | #14 |
Moderator
Is there voltage on the sender wire? That's the only way I know to make the gauge read below E.
A tan wire runs to the valve on the frame? Has your truck been retrofitted with an '80s motorized valve? This is the 1974 factory dual tank schematic from the 1974 wiring manual.
10-31-2012, 09:54 PM | #15 |
okay well i guess its off under the truck tomorrow then
how can you tell which tank is the aux? driver or passenger? Will try to get some more pics side question i took all my wires apart, they were wrapped in electrical tape im still working on the electrical, but i dont want to leave it just exposed should i re wrap it all in tape or zip tie them... dont want to really put loom next to a hot engine
11-01-2012, 09:35 AM | #16 |
Moderator
Aux is the tank that's activated when the solenoid has power. The dash switch selects the sender as well as powering the solenoid in the AUX position.
According to the GM wiring diagram the AUX tank sender has a LT BLU sender wire and the primary tank has a TAN sender wire. That diagram came out pretty grainy after the Board Upload software cut the resolution in half. I scanned 400dpi PDF files of the 74 Chevrolet Light Truck Wiring manual along with the 74 Service and 74 Overhaul manuals. They can be found in the linked thread in my signature.
11-01-2012, 03:38 PM | #17 |
okay guys well i went over the wiring and everythings correct
sorry i was wrong about the wire that i thought went to the selector valve This is the way its routed on my truck exactly im gonna check the fuel tank switch right now let me know if its right
11-01-2012, 07:47 PM | #18 | |
11-01-2012, 09:13 PM | #19 |
okay guys well heres a update
i think i finally got it What i did was switch out gauges if i bench tested it right the gauge i had in their was bad swapped in another gauge i i get these readings now left tank around 3/4 of a tank right tank reads about the 3 o clock position(it might be a bad ground) i havent been able to drive the truck around to find out if i fixed it or not --- Also i painted my gauge needles with some family dollar nail polish to make it all match lol the pic without the plastic is the before pic and the one with the plastic is the after pic ---- another side question the last pic this is behind my ac control switch i dont see no plug for the 3 prongs sticking out or the other little prongs look like for a vacuum?? TIA
11-02-2012, 06:35 PM | #20 |
Frog that exactly what my truck does... If it's on the passenger side tank it work fine... as soon as I flip it to the driver side tank the gas gauge is at 3:00.Don't know if this helps you? But I never use the drivers side and it's always empty.
11-05-2012, 08:05 AM | #21 |
78K & 79C Jimmys
the last pic this is behind my ac control switch i dont see no plug for the 3 prongs sticking out or the other little prongs look like for a vacuum?? looks like heat/AC controls vac lines...to a female plug of them and the speed switch....is it heat only(non AC)?
11-02-2012, 08:56 PM | #22 |
Okay goes well guess what???...
. . . My gauge works thanks all you guys for the help My sender is a spectra and i know i saw somewhere here that the sender makes the needle on the gauge bouncy, it is when i drive the truck it bounces like almost a 1/4 or more, I left the truck on when i put gas in and was watching the gauge , it went up while i was putting the gas in it, went up a little pass the full mark, so i will have to see how it works now have to see where the new full is at and Empty but im happy Thank yall for yalls help
11-03-2012, 07:13 PM | #23 |
Its a combination of the sender AND the fuel gauge. GM really screwed the pooch on that one. For example, mine used to be the same way. The needle was wavy to the point that the gauge was almost unusable at times. But then I put in an autometer fuel gauge, and it stopped waving. Now it does still move. But when it does its slow, and not nearly as frequently. So at least I was able to cut the fuel gauge out of the wavy needle equation.
As for getting the rest out, I'm thinking you'd have to go with a newer tank or something with way better baffles. Cause you can spend a lot of money on a good ACdelco brand sender for the tank, and that's probably the best one you can buy. Too bad that's likely what they came with lol |
11-03-2012, 08:10 PM | #24 | |
Moderator
Th C2 Vette guys mention it in this article... http://www.lbfun.com/warehouse/tech_...nding_unit.pdf
11-03-2012, 08:33 PM | #25 |
I wondered if i could use heavy grease
i dont know any good gauge guys around here in my area unless their some people yall can recommended me to online
