How low are you goin and still towin?
I want to lower my 67 and still be able to tow a loaded car trailer or or 20 ft camper.how low are you going and how did you do it? lets see some pics with attached trailers.
Re: How low are you goin and still towin?
Here is "NACHO" doing work!!
![]() Join Date: Oct 2012
now thats low, really cool, keep on truckn
I plan on towing with a static 4.5/5.5-6 drop. I will have to see how that works out.
Here is the build thread alot of great info on o great build good read.
![]() http://67-72chevytrucks.com/vboard/s...ighlight=nacho |
is that it one guy using a lowered truck to tow? by the way nice truck cok5.
My 68 stepper is 4.5 in the front and 6.0 in the rear, I pull my bass boat with it and no problems.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
maybe I should change my question. I know how to lower it. what I want to know is what after market lowering springs will take a load? are they all about the same or are some better.
heres mine should be lower when i finished...
72 swb pickup http://i124.photobucket.com/albums/p...k/100_0958.jpg 1967 chevelle ss 1966 mustang getting a l33 ls motor 1969 chevy dump truck 1989 mustang 6.0 ls best time of 1.29 at 5.91 https://www.youtube.com/watch?v=JtbooZoGZmQ |
Junior Member
I have a 4/7.5 ish static. This is my buddies jet ski. No problems but it is light. I'm planning on bags in the rear so I can pull my car trailer or boat. The way I see it is, being lowered you don't have much room for squat from the tongue weight. Any spring that wouldn't compress much is going to ride hard.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#13 | |
You asked what springs i used, ece supplied them,and yes i'm close to the bump stops and depending on the road hit them on ocassion. the only way i know of get a higher rate spring is getting eaton spring to make some. Heard of some folks using air bags on the trailing arms for when hauling a load. hope this helps
Drop spindles with 3/4 coil cut front, heated springs rear.
#15 |
You guys running a c notch or something? I dropped my 68 4/6 and I know it's very close to the bump stops.
#16 |
i have drop leaf springs,,,
#17 |
Not a 67 72, but full air ride!! cruise and pull with no problems
67- 72 Parts collecter |
#18 |
Registered Cruiser
Hooked up to my new buggy trailer.
I intend to live forever. So far, so good. |
#19 |
the boat guy
4 6 drop, springs. Hits the bumpstops with a load or hauling but I haven't died yet.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#20 |
///Relaxed Atmosphere
not much weight but it gets the job done. E.C.E 6 inch rear coil and half inch block trimmed the bump stops about a half inch no rubbing.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#21 |
Not a 67-72, but the sky is the limit really.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#22 |
![]() Join Date: Apr 2005
I think you meant to say "the ground is the limit"........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
