10-28-2012, 05:13 AM | #1 |
spindle quesion..
so i heard that you can use lowering spindles as lift spindles by fliping them around and using the right one on the left and the left on the right, has anyone heard about this? it kindaa sounds like itll work. let me know what you guys think.. if itll work i might just try it.. any help works thanks guys..
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front 73 c20 custom deluxe sm465 14bff parts truck |
10-28-2012, 06:49 AM | #2 |
Re: spindle quesion..
and flip it upside down to so you can still use the tie rods and that only thing i cant figure out is the breaks would be on the front would that still work?
10-28-2012, 07:07 AM | #3 |
Watch out for your cornhole !
No.
Your upper and lower ball joints are drastically different so you're not going to be flipping anything over and still have the ball joints fit into the holes. And your steering can't be swapped around to be behind the crossmember. There's a big old engine right in the way.
