11-01-2012, 08:00 PM | #1 |
G-TR Rear Coil Over Suspension
Wanting to do a static drop on the rear of your '63-'72 but don't want to settle on one height? Our G-TR coil over rear suspension is almost finished up and coming to market soon! Expect an approximate drop range of 4" to 6" Watch for details and prices to be posted soon.
11-03-2012, 08:12 PM | #2 |
Re: G-TR Rear Coil Over Suspension
Subscribed
Posted via Mobile Device |
11-03-2012, 09:59 PM | #3 |
Interested in more details.... Are you doing the front as well?
11-04-2012, 10:52 AM | #4 |
11-04-2012, 10:46 AM | #5 |
This pic with the bed on may give a better "visual" as to how much the rear is lowered. This is at the lowest setting of approximately a 6" drop.
As far as details go, -The ride height will be adjustable from approx. 4"-6" -Shocks are moved into a vertical position to work more effectively with the suspension movement. -Maintains maximum tire clearance by containing all components within the frame rails. -Both upper and lower shock mounting points are a double-shear type, capturing both sides of the shock for improved strength and durabillity. -Uses factory frame holes for a true "bolt-in" installation. -Heavy Duty double adjustable panhard bar with QA1 XM Series Chromoly rod ends allow for easy centering of the rear-end. -Grade 8 hardware included. -QA1 Single Adjust Coilover shocks included with 400 lb springs, other spring rates available at customer request. -Can be ugraded to Double Adjust Coilovers for $200 added price. -Retail price is set at $1,200 for the full kit with Single Adjust Shocks. Forum Memebers save $100 -Base kits without shocks can also be purchased for $700, Forum Member price $650. |
11-04-2012, 02:52 PM | #6 |
67-72 parts collector,…
Does the lower shock mount attach to the rearend or the trailing arm?
11-04-2012, 04:51 PM | #7 |
The lower mount is attached by a "C" bracket the wraps around the trailing arm and is captured both top and bottom by the U-bolt used to bolt the rear end in place.
11-05-2012, 10:26 AM | #8 |
Boosted Member
400 lb/in springs? Is that what is required to hold these trucks up in the rear? What is the travel of those shocks?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-05-2012, 01:24 PM | #9 |
Factory springs are rated right around 600 lb/in. We start with a 400 lb spring as a base line to improve performance characteristics/weight transfer without giving up to much with load capabilties. (It's not so much designed for hauling or towing heavy loads as it is for performance gains) Just for comparison, the Hotchkis 6" rear springs are rated at 380 lb/in. The coil overs have an approx. travel of 5.375" with an 11.625" compressed height and 17" extended, using a 12" spring.
11-05-2012, 02:34 PM | #10 | |
Boosted Member
11-05-2012, 01:32 PM | #11 |
Any way to use a shorter shock to keep the lower bracket above the trailing arm,... for scrubline issues?
11-05-2012, 04:51 PM | #12 |
Yes, a shorter shock can be substituted and then adjust the lower bracket location to compensate. The trade-off would be a shorter shock travel, roughly 4" instead of 5"+. That's where our base kit package can come in handy, the customer can choose their own coilovers. One note, though, we developed this kit to use QA1's or a similar shock with the knobs at the bottom for ease of access for adjustment. Not that brands with the adjustment knobs at the top won't fit, we just haven't tested that style for any clearance issues yet.
12-24-2012, 02:04 AM | #13 |
The 60-66 GMC/Pontiac guy....
Do you have anything on front coil over suspension?
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
12-24-2012, 10:29 AM | #14 |
That should read "Do you have anything for the front suspension in the works??"
Not sure what is going on but I had to try and post this 3 times to get it to post at all.. ??
12-26-2012, 02:15 PM | #15 |
Currently, no. It could be a possibility in the future, but we are focusing on rear suspension products at the time.
12-26-2012, 04:34 PM | #16 |
What kind of trailing arm is pictured? Do you make those? Exactly what is included in the kit for $1200?
12-27-2012, 11:19 AM | #17 |
We developed this kit using Early Classic Trailing Arms, which are a 1/4" taller that the stock ones, but a spacer is included for those still running stock. This makes the kit somewhat universal. We are planning on our own trailing arms next year that will incorporate the lower mounts right on the arm instead of using a seperate bracket. They will also have a spherical bearing for the mounting point instead of poly or rubber bushings, but we are working out the details. The kit would then be available in two configurations, without the arms if someone wanted an ecinomical bolt in kit, or with the arms for a complete rear suspension upgrade. We are forcasting an approximate price of $1,400-$1,500 for the complete kit. The kit listed above will have the bolt in frame crossmember, lower shock brackets, double adjustable panhard bar with QA1 Chromoly rod ends, single adjustable QA1 bearing mount shocks with #400 springs (other rates available per customer request) and all grade 8 hardware included.
12-27-2012, 11:20 PM | #18 |
sweet. looks like what I need. I could get a real wide tire on my 67 then.
12-31-2012, 12:59 PM | #19 |
01-01-2013, 12:16 AM | #20 |
01-01-2013, 11:02 AM | #21 |
The tires/wheels that are in the photos 295/45 mounted on 18x9.5 with 4.75 backspacing on a stock width axle. These measure out to about 28.5" tall and 11.5" wide and there is room to go at least 4" wider toward the frame.
12-31-2012, 01:15 PM | #22 |
LOL! I just noticed the carpet in your photos...
Reminds me of hiding in friends garages in Michigan during the winter, standing close to a wood stove staying warm... I moved to Arizona from Ludington.. was born in Howell... What memories...
06-15-2013, 03:22 AM | #23 |
Is the rear suspension on the '60-'62 that much different that this can't be modified to work? I have an '85 front suspension in place of the torsion bars, and I have removed the "X" frame. I plan on using a couple of the tubular cross braces from Porterbuilt to add some rigidity. Think it'll work?
06-15-2013, 08:29 PM | #24 | |
06-15-2013, 08:59 PM | #25 |
The frame on a 60-62 is significantly wider in the rear ...
Not even close to the same as the 63-72
