Old 06-01-2003, 03:26 PM   #1
adkphoto
327: Small or Large Journal
Buddy of mine gave me a 327 all machined with 4-over pistons, 2-under crank. (Yep, for free :-) Need to get rings and bearings for it.
Anybody know exactly how to tell if it's a small or large journal engine?
David
1972 Chevy Cheyenne Super LWB
Chevy Red/White with rally wheels.
Not-so-Stock 350, A/T, A/C, tilt.
Vroom, Vroom....
David Colbert dcolbert@twcny.rr.com
Work hard, play harder!
adkphoto is offline   Reply With Quote
Old 06-01-2003, 04:17 PM   #2
jhwkns
Registered Cruiser
jhwkns's Avatar
I'm not positive but I beleive that the small journal engines had pressed on vibration dampers, and the large journals are bolted on.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 06-01-2003, 06:06 PM   #3
Rod
You could look up the suffix code at nastyz28.com and if its a 68 block its large journal.. everything older is small journal.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-01-2003, 06:17 PM   #4
sbc350gearhead
sbc350gearhead's Avatar
Small journal cranks have 2.3 inch mains and 2 inch rod journals. Large journal cranks have 2.45 inch mains and 2.1 inch rod journals. and jhhwks is right most large journal cranks have the nose drilled for a balancer retention bolt.
sbc350gearhead is offline   Reply With Quote
Old 06-01-2003, 06:22 PM   #5
crazy longhorn
Fabricate till you "puke"
the quickest way to tell at a glance......the rear flange(that the flywheel bolts to), is round(machined) with 2 notches cut out on the SJ crank. The LJ crank has a more oblong shape on the rear flange(like a little counterweight added). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-02-2003, 08:29 AM   #6
adkphoto
You guys are awesome. Thanks!
Turns out to be a large journal engine.
David
Vroom, Vroom....
